Subject: Do I have the correct file for Judy? Wardrobe Wizard not working.
operaguy opened this issue on Dec 04, 2005 ยท 16 posts
operaguy posted Sun, 04 December 2005 at 7:08 PM
Wardrobe Wizard..... Having trouble converting clothing, any clothing, to Judy. WW working fine otherwise, Jessie --> V3, V3 --> Jessi, etc. 1) is anyone out there using WW to convert to judy, and is it working for you? 2) is this the correct geometry for judy?: P5NudeWoman.obj size: 3705 KB Modified: 8/12/2002 7:47? Error I get is: -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Error! Traceback (most recent call last): File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 2293, in ChooseMenuItem File "", line 1, in ? File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 491, in ConvertTo IndexError: list index out of range 'list index out of range' -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Thanks for anyone who can help, ::::: Opera :::::
Acadia posted Sun, 04 December 2005 at 7:16 PM
I was going to try a from Judy to V3, but I can't decode the file I need. I'm checking my CD's and my desktop to see if I happen to have lucked out and saved the Objaction Mover somewhere else.
PhilC posted Sun, 04 December 2005 at 8:48 PM
Yes could you please post your OBJ statistics. I have a sneaky feeling that there is more than one version of the Judy file.
You can read these statistics in UVMapper or any 3D modeling application.
Thanks,
Acadia posted Sun, 04 December 2005 at 9:02 PM
I have used "Judy Nude" for my "Convert from", and have had no problems using Wardrobe Wizard. Opera, which Judy are you trying to use (hair, hires, nude)?
operaguy posted Sun, 04 December 2005 at 9:32 PM
Acadia, "Judy Nude" But Acadia, my problem is the other way around, converting TO judy. It is failing as I convert to. I am converting from Jessi clothes and V3 clothes, etc. to judy. Phil: Per UVMapper vertices = 24407 24407 textures = 24863 26473 *** normals = 24407 24407 facets = 24387 24387 groups = 76 76 materials = 17 17 only textures is different ::::: Opera :::::
Acadia posted Sun, 04 December 2005 at 9:39 PM
I'll try a from V3 to Judy Nude and see what happens. I'll post back.
PhilC posted Sun, 04 December 2005 at 9:41 PM
Thanks, I'll double check that in the morning. ... Just thought are you converting with genitalia turned on or off?
operaguy posted Sun, 04 December 2005 at 9:56 PM
thanks acadia, that would help a lot. This might just be me, or maybe not. checking that other delicate item next. og
operaguy posted Sun, 04 December 2005 at 10:18 PM
WHOA! Stop the presses. THAT WAS IT! I turned off genitalia and just converted a Jessie business suit and a complex V3 batlab flowing garment to Judy with no error. Thank goodness! Judy was getting cold. ::::: Opera :::::
Acadia posted Sun, 04 December 2005 at 10:23 PM
Ok, I did an outfit from V3 to Judy Nude, and I got the same error as you have: -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Error! Traceback (most recent call last): File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 2293, in ChooseMenuItem File "", line 1, in ? File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 491, in ConvertTo IndexError: list index out of range 'list index out of range
Acadia posted Sun, 04 December 2005 at 10:26 PM
Don't know what you did to get it to work. I still get the error. How do you "Turn off Genitals" on a figure?
operaguy posted Sun, 04 December 2005 at 11:09 PM
in P6, under the "FIGURE" menu is a choice "genetalia" which I believe is check on by default. Just uncheck it. og
Acadia posted Mon, 05 December 2005 at 6:05 AM
And in Poser 5?
Khai posted Mon, 05 December 2005 at 6:13 AM
same same in 4 and PP as well
TrekkieGrrrl posted Mon, 05 December 2005 at 6:14 AM
Same place in Poser 5
Acadia posted Mon, 05 December 2005 at 6:28 AM
Thanks, I'll give it a try when I open Poser later.
