Forum: Carrara
Subject: poser 6 import success
thomllama opened this issue on Dec 11, 2005 ยท 39 posts
thomllama posted Sun, 11 December 2005 at 8:57 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1110876&Start=1&Sectionid=6&filter_genre_id=0&WhatsN
I just posted a quick test import using poser 6 and transposer with carrara 5 final version.... take a look came out pretty good. onlt trouble was the hair and body didn't aligned, I had to re position
Hexagon, Carrara, Sculptris, and recently Sketchup.
Hoofdcommissaris posted Sun, 11 December 2005 at 10:32 AM
I had a fatal crash (Mac OSX 10.4) with dynamic hair, every time I tried. Did not test more.
I did a quick test with dynamic cloth and an imported Poser figure (bald, because of the mentioned crashing) and translucency, she is lying on a extremely glowing box.
thomllama posted Sun, 11 December 2005 at 10:41 AM
OS10.4.3? what do you have for ram? what type of Mac? G5? I have to say that once i import a poser file My version 1 G5 dual 1.8 slows pretty heavy
Hoofdcommissaris posted Sun, 11 December 2005 at 10:50 AM
G4 double 1.4 Ghz with 1Gb of DDR SDRAM. (A G5 dual is due for next year) It rendered until it 'touched' the hair part of the render. And then crashed the whole program.
thomllama posted Sun, 11 December 2005 at 10:57 AM
I'm guessing not enough ram.. it's pretty intense on the computer importing the dynamics... and it's dogging mine with 2 gig. try using transporter or just native? turn off animation?
agiel posted Sun, 11 December 2005 at 10:58 AM
So far, my attempts at importing pz3 files into Carrara have failed about half of the time, With Transposer, I end up getting empty figures. They are listed in the list of objects in teh scene but they are simply not there. With the Native import, I get 'missing texture' warnings (which are a pain to go through when Carrara doesn't even remember that I just selected a body texture and asks me 5 times to locate the same texture map). Once the popups are over, I end up with a figure that has lost its pose most of the time. I was impressed with the beta but at this point, this is so unreliable than it is pretty much useless to me.
thomllama posted Sun, 11 December 2005 at 11:05 AM
"With Transposer, I end up getting empty figures. They are listed in the list of objects in teh scene but they are simply not there." try going and setting XYZ all to zero.. I have noticed that it places the figure off into the ozone... but it's there. asto finding the texture maps... I'm guessing you have poser 5 also. a lot of textures that poser 6 uses are still located in the poser 5 folder... bla bla bla.. when you asign poser 6 to carrara it doesn't know to go to toe poser 5 runtime to find stuff,... this is just a guess though but worth trying, take all your textures and stuff from 5 and actually install in 6
agiel posted Sun, 11 December 2005 at 11:16 AM
Thanks, I will check again for the position of the objects. I have poser 6, with only one runtime.
steama posted Sun, 11 December 2005 at 2:47 PM
I am having great luck with importing Poser 6 files both natively and with Transposer. It is working as advertised for me. I'm on a PC. My Poser 6 runtime has been combined with Poser 5 content so I have just the Poser 6 Runtime (enhanced) and the Download Runtime (also P6 SR2 update installed). Eovia is great! I almost thought P6 was a waste. I even uninstalled Poser 5 yesterday.
Goodluck everyone,
Stan
Message edited on: 12/11/2005 14:59
arcady posted Sun, 11 December 2005 at 5:32 PM
1gb of ram isn't enough for Carrara?
Do these poser issues with hair and transposer issues with dynamic hair mean 'patch time' sometime in the near future?
Will I be likely to face these issues with Poser 5 rather than Poser 6? If Carrara has all the features it seems to have, my reasons for considering an eventual Poser upgrade might not be that valid anymore - unless it makes it more difficult to integrate with other apps.
Message edited on: 12/11/2005 17:34
Truth has no value without backing by unfounded belief.
Renderosity Gallery
thomllama posted Sun, 11 December 2005 at 5:39 PM
I'M Just guessing there. actually I have tried to render a more detailed file with jessi import and it seems to always crash carrara just when the render hits Jessi.. working on more detail
bwtr posted Sun, 11 December 2005 at 6:11 PM
arcady. I think its not just the ram but the amount of free space in the scratch disk. I am fortunate to have some 18GB free in the scratch disk allocation. However,Carr5 does not seem to work at any where near the same quality level with Poser6 stuff as it does with Poser5 stuff . We can but hope that a fix is in the pipeline.
bwtr
thomllama posted Sun, 11 December 2005 at 6:30 PM
yaa.. i havwe been playing and now am getting a returning crash/quit when trying to render images with poser 6 imports
ShawnDriscoll posted Sun, 11 December 2005 at 9:00 PM
I'll have to try rendering the White Queen version of Jessi from the SE version of Poser 6 in the Carrara house on my P3 1GHz 1GB RAM system with Carrara Pro 5.0.1 and see if it crashes.
dlk30341 posted Sun, 11 December 2005 at 9:55 PM
I agree with Agiel...in addition to not finding textures, there are other issues...see the the next 4 images.... 1. Images aren't mapping correctly 2. In one case the geomotry isn't coming in correctly. The next 4 images show what it should like vs what it DOES look like Image one XMas stockings imported into Carrara5P
dlk30341 posted Sun, 11 December 2005 at 9:57 PM
Note the above pic(the one above this one).....the stocking geometry is fubared.
This how they should look
Message edited on: 12/11/2005 22:00
dlk30341 posted Sun, 11 December 2005 at 9:58 PM
Note the texture mapping is all amiss.
dlk30341 posted Sun, 11 December 2005 at 9:59 PM
As stated above
arcady posted Sun, 11 December 2005 at 10:18 PM
Well I think the first bookshelf is more interesting, in a Salvador Dali sort of way... yeah, looks like a patch is needed. :) You should send this on to eovia, if you haven't already.
Renderosity Gallery
ren_mem posted Sun, 11 December 2005 at 10:22 PM
Does there seem to be any thread here...Is mac working worse than pc etc...really helpful if you posted specifics.Everyone got p6 patch? I would definitely report to eovia.1gig of ram should not cause this that is for sure. Could a texture path issue be to blame or certain file format? Have you got anymore insight after looking at the textures once they come in?
No need to think outside the box....
    Just make it invisible.
dlk30341 posted Sun, 11 December 2005 at 10:48 PM
Already reported.....
Poser6 Sr2..WinXP Pro...4G of ram & Nvidia 6800Ultra/on board 256K. P4 3.2GHZ The bookcase worked in C4P :) I saved it out of there as a .car to work in the scene I'm working on. Was Using Poser 6 there as well :) The stockings didn't work in either C4P or C5P.....They are from a package at Daz called Christmas Past. That said...all worked fine in other applications :)
Message edited on: 12/11/2005 22:51
glought posted Sun, 11 December 2005 at 11:06 PM
I'm with Steama. I am on a PC and have had great luck with Poser 6 files and animations. Just watch the hair. The Update for C5 looks to fix some of the trouble I have had before.
R_Hatch posted Mon, 12 December 2005 at 12:21 AM
When you use them in Poser, do those stockings by any chance use a morph to attain the 'stocking' shape? Or is the 'cup' shape a morph? Perhaps even a hidden morph that is in the CR2/PP2 that doesn't have any visible dials in Poser?
steama posted Mon, 12 December 2005 at 2:12 AM
Things seem to be working qiute well with Poser 6 and C5Pro. I have experienced one anomaly, however, using Transposer with the link to the Poser file selected I went back into Poser and made some edits, re-opened my Carrara scene and the textures went nuts on render. I opened the same figure in a new document and all work well again. I really don't expect it to be perfect but a reliable way to import Poser 6 files. It seems to be doing that quite well. I hope Eovia can address the problems some of my forum colleagues are having. Good Luck to all, Stan
bwtr posted Mon, 12 December 2005 at 2:24 AM
Anyone been working with the "bargain" Zygote Galleon? Can you get it to work in Carrara?
bwtr
Ringo posted Mon, 12 December 2005 at 7:56 AM
Looks like the Mac version needs an update. Anways Eovia always releases an update a bit later after a release. I'm sure the will be updating it. Ringo
agiel posted Mon, 12 December 2005 at 1:42 PM
I gave it another try last night :
And I get the same problems as reported before.
With Transposer, my character appears completely empty.
I checked position and scale - not a problem. It looks like the object just has no geometry.
With Native import, I didn't go through the whole texture import thing . I gave up after a warning of missing .obj file and the first warning of missing texture.
I guess I will have to wait for the update. For the record, I am running XP, Poser 6 SP2 and I have more RAM than I know what to do with...
Message edited on: 12/12/2005 13:49
steama posted Mon, 12 December 2005 at 4:36 PM
Agiel, do you have the correct Poser application path selected in the Transposer import dialog? Also, with native import all you have to do is drive to or do a search to find the missing .obj file and import will find everything else. At least that is the way it worked for me at first. Now I can just import any figure. Carrara needs to know where the geometry is in the runtime or where ever you have it on your computer. Good Luck, Stan
agiel posted Mon, 12 December 2005 at 4:52 PM
Yep to #1. About #2, it still asks me each time I try to load it.
ShawnDriscoll posted Mon, 12 December 2005 at 11:59 PM
I imported the Winter Queen from Poser 6 SE into Carrara Pro 5.01 and she was standing in the Carrara House beautifully. When I rendered the scene with Ambient Occlusion, her eyes were totally black though. So I thought her eye textures were clobbered like in the old TransPoser 2. But when I shined a bulb on her face, her green eyes were there just fine. No crashes using just imported Poser 6 content.
estherau posted Tue, 13 December 2005 at 6:40 AM
Are you all using transposer 2.1? It's on the eovia site. Love esther
MY ONLINE COMIC IS NOW LIVE
dlk30341 posted Tue, 13 December 2005 at 10:37 AM
I'm using native Poser import & whatever version they included in the final release. C5Pro...should be updated to 2.1...as it comes with final.
Message edited on: 12/13/2005 10:41
bwtr posted Tue, 13 December 2005 at 8:53 PM
esther. Trying to load the 2.1 update into C5Pro tells me that C5 is not properly installed!!! (I have reported it) I am having problems with stuff from Poser,even imported as .obj or 3ds either crashing Carrara or coming in with nil size or -------minus size. I am close to expunging Poser6 from the computer, AGAIN, because it may be the cause of all my troubles.
bwtr
ShawnDriscoll posted Tue, 13 December 2005 at 10:58 PM
CPro 5 already includes the latest version of TransPoser. The download on Eovia's site is for standard C5.
R_Hatch posted Wed, 14 December 2005 at 5:49 AM
Poser 6 support is excellent; even pulls in CRZs with ease. I can't wait until I'm using the real deal instead of the demo :D
charlesb posted Thu, 15 December 2005 at 4:58 PM
Hi, we are currently trying to figure out what's causing those issues. Could you please email me directly at charles@eovia.com if you are having problemes with TransPoser? I would like to understand why it works for most people but not for some.... Charles
dlk30341 posted Thu, 15 December 2005 at 6:32 PM
I'm using Poser Native :)
charlesb posted Thu, 15 December 2005 at 6:44 PM
For problems with the Native Importer, please email pierre@eovia.com thanks Charles
charlesb posted Wed, 21 December 2005 at 2:36 AM
Hi, we are not able to reproduce most of the issues posted on this thread and no one is emailing me to give more details... If you are having issues with the Poser import please email me at charles@eovia.com and we will fix them... The good news is that we fixed several other issues and we will release an update soon. Charles
