Subject: Zygote Galleon
bwtr opened this issue on Dec 12, 2005 ยท 6 posts
bwtr posted Mon, 12 December 2005 at 6:37 PM
I purchased the $1.99 Galleon from Content Paradise however it seems to be faulty in both Poser5 and 6. Worse,when I try to import into Carrara it completely crashes it. Any comments or suggestions please?
bwtr
randym77 posted Mon, 12 December 2005 at 7:07 PM
It works fine in Poser 6 for me. But it's a huge model. Both in size and in polys. It's so big that it slows Poser to a crawl. When it comes it, the camera is inside the ship. You won't see it correctly until you pull the camera back. Way back.
bwtr posted Mon, 12 December 2005 at 8:50 PM
Have you joined all the bits and saved it into the browser and then tried to open it and get full details to render? The hull seems to dissapear. (Even loading the .obj files into Carrara crash it!)
bwtr
randym77 posted Mon, 12 December 2005 at 9:16 PM
As far as I know, that's normal behavior for props. The sails, wheel, etc., are smart props. But if you try to save the galleon to your library, it only saves the active prop. It doesn't save the others with it. (Note that it doesn't ask you if it should save just the active item or everything when you save it.)
I suspect that's why your hull is not showing. It wasn't saved.
I don't have Carrara, but I tried importing the galleon to Vue. It came in fine.
bwtr posted Tue, 13 December 2005 at 12:06 AM
Thanks. Will try more out.
bwtr
aeilkema posted Tue, 13 December 2005 at 7:17 AM
Should work fine in P6, I've used a couple of times without any problems.
Food for thought.....
