Subject: Problem with background images
Lakeesha opened this issue on Dec 13, 2005 ยท 4 posts
Lakeesha posted Tue, 13 December 2005 at 9:45 AM
Heya,
as the topic says I have a problem with my background images. After I prescind from using them by importing them directly, because they became pixelating, I started to use a simple prob square with the image as texture.
A long time it went good but now a problem came up. Rendering a poser 4 image in poser 6 I see black horizontal stripes on the background.
A firefly image causes the problem you can see on the attached image. The background should be yellow.
Could anyone tell me why that happened or what I can do to prevent it?
Thanks for your help,
Jess
Message edited on: 12/13/2005 09:46
EnglishBob posted Tue, 13 December 2005 at 9:48 AM
Don't use the double sided square prop, since Firefly has trouble with double sided polygons. Use the single sided square and all should be well.
pakled posted Tue, 13 December 2005 at 10:09 AM
or failing that, try making the background image (file|Import|Background image)the same size as the pic you're doing; that should cut down on pixellation. It works in Version 4, at least..;)
Lakeesha posted Tue, 13 December 2005 at 10:20 AM
@pakled: that won't work because the wanted image is double size of my monitor :-) but thanks. @bob: thanks very much, it worked perfectly :) The result will be shown in gallery as "june"-part of my calendar soon :)
