Subject: How do you turn a other charater around without messing up its legs
lord_cylon opened this issue on Mar 14, 2001 ยท 7 posts
lord_cylon posted Wed, 14 March 2001 at 4:05 AM
How do you turn a other charater around without messing up its legs , like to make them face each other...
sama1 posted Wed, 14 March 2001 at 4:43 AM
I belive you can select 'body' for the figure and use the rotate dial. Sam
ookami posted Wed, 14 March 2001 at 6:57 AM
Sam is correct. Select the character you want to turn. Make sure you have BODY selected. Then rotate it with the ROTATE X,Y,Z dials until it is properly oriented, then move it to the proper location.
Huolong posted Wed, 14 March 2001 at 8:20 AM
  1. Figure/Use Inverse Kinetics: Uncheck the legs. 2. Select body as above OR 3. You can move a body around by it's hips if you uncheck the legs. 4. Sometimes, you can move an entire body with the editing tools if there isn't another body parked directly under them.
Gordon
Anthony Appleyard posted Wed, 14 March 2001 at 9:45 AM
If you know what you are doing, go into the CR2 file with a text editor and find these lines for each leg;s IK chain:-
        inkyChain     rightLeg
                on
                name Right Leg
and replace "leg" by "legg" (and replace the "on" by "off"). That will stop all that stupid automatically setting the legs IK-on, for that model. That annoying mechanism also IK-parents the feet to the character's BODY. That is why the feet stick to the ground when you move his hip but not when you move his BODY. His BODY is an invisible part which is parent to his root segment.
mikes posted Wed, 14 March 2001 at 10:26 AM
Also try the Symmetry controls to mirror or swap things left to right.
lord_cylon posted Wed, 14 March 2001 at 11:11 PM
Thankies people! you helped me alot :)! Cya
