pobble opened this issue on Dec 15, 2005 ยท 1 posts
pobble posted Thu, 15 December 2005 at 10:53 AM
Just wanted to point out how great the freebie "Le Restaurant" from aaa3d is! Thank you so much. So much detail and even a full moon in the sky ;) Merci beaucoup!
I found just a couple of problems with the texture references in the .pz3 and the main prop. If you spend 5 minutes with a text editor you can clean those up. Search for "metallic.jpg" and correct the path.
