AZAD opened this issue on Dec 15, 2005 ยท 5 posts
AZAD posted Thu, 15 December 2005 at 7:33 PM
all the sudden , my right click save is not working properly when i right click to save , only option i get is a bmp with untitled as a file name when it should be jpeg format and a given name of file by the publisher which setting have i changed without knowing help please thank you
Hawkfyr posted Thu, 15 December 2005 at 7:36 PM
I've heard of this problem before. As I recall,it happens after you have saved tons of images off the web. If I recall correctly,you should clear out your browsers Cashe,and it should give you back the .jpeg/.gif options. hope it helps Tom
“The fact that no one understands you…Doesn’t make you an artist.”
AZAD posted Thu, 15 December 2005 at 8:39 PM
steps to do that "safely" , if no one else has a solution thank you
SeanE posted Thu, 15 December 2005 at 8:50 PM
in IE6... tools - internet options - clear history - and also 'delete files' (do not select 'delete offline content' as well!!) and also 'delete cookies' that should do it...
AZAD posted Thu, 15 December 2005 at 8:58 PM
PROBLEM SOLVED THANK YOU
