DuBetzDesigns opened this issue on Dec 16, 2005 ยท 14 posts
DuBetzDesigns posted Fri, 16 December 2005 at 5:42 PM
I tried to look through other posts before posting this question and couldn't locate an answer. By default the Poser window saves images 9.264" wide and 6.389" high. How do I flip that? So the 9.264" is the height? Also, I've sent emails to the Renderosity store and have yet to receive ANY response, does anyone know why? I sent them to fdteam@renderosity.com Thank you in advance.
randym77 posted Fri, 16 December 2005 at 6:19 PM
Which version of Poser are you using? You can change the image to any size you want (well, within reason). It's in render dimensions or render options, depending on what version of Poser you are using.
KarenJ posted Fri, 16 December 2005 at 6:30 PM
For store contact, please email store@renderosity.com. I don't recognise the email address you've been sending to... did you get that from a page on here? I'll have it amended if so... Karen Poser Mod
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
DuBetzDesigns posted Fri, 16 December 2005 at 6:41 PM
Randym77, I'm using version 6.0. Thank you for the tip, but is there anyway to have a workable canvas, prior to rendering, that's higher than wider? I know, it's a stupid question as I can pull the camera view out, I'm just used to Photoshop and controlling the canvas. Karen, yes I did. Give me a couple seconds and I'll try to relocate it on the site.
randym77 posted Fri, 16 December 2005 at 6:43 PM
Window -> Document Window Size.
DuBetzDesigns posted Fri, 16 December 2005 at 6:49 PM
Sure...make me feel stupid :-) Thanx Randym77
DuBetzDesigns posted Fri, 16 December 2005 at 7:33 PM
Karen, I haven't been able to locate that email, let me click around a bit and I'll find it. I'll PM you when I do.
SamTherapy posted Fri, 16 December 2005 at 8:04 PM
Nother tip... You can change to any size by unchecking the "Aspect ratio" option. Great for 16:9 (or 19:6) images. :)
DuBetzDesigns posted Fri, 16 December 2005 at 10:02 PM
Sam, where do I find the aspect ratio?
SamTherapy posted Fri, 16 December 2005 at 11:44 PM
You don't. Normal computer and TV images are 4:3, widescreen is 16:9 What you have to do is a little math. Example, the following are 4:3: 640 x 480 1024 x 768 1600 x 1200 and so on... What you have to do is work out which size and formatworks best for you.
DuBetzDesigns posted Sat, 17 December 2005 at 4:31 AM
Thanx Sam, I realize, now, what you meant and thank you much for your input, I really appreciate it.
SamTherapy posted Sat, 17 December 2005 at 10:47 AM
alexic posted Sat, 17 December 2005 at 7:26 PM
Window -> Document Window Size has limits (1265x1009 in P5, no idea where they got those numbers) but you can go to Animation -> Movie Output Settings and set whatever dimensions you want, (uncheck 'constrain aspect ratio') and export one frame with sequence type = image file, you should be able to create an image size that will crash any pc.
DuBetzDesigns posted Sat, 17 December 2005 at 8:06 PM
Thank you Alexic, I'll try that as well.
