Subject: Help with Tawnie Renewal
spiritwolf2000 opened this issue on Dec 22, 2005 ยท 12 posts
spiritwolf2000 posted Thu, 22 December 2005 at 3:30 PM
I have a weird problem I just purchased Tawnie Renewal by Morris in the MP. I dont know whats causing it Im using light set from another character pack that I have used bunches of times. Ive also changed the lights to differnt sets with no results. I believe it is something to do with the material settings but I dont know much about the material room. I am attaching both a screen of whats happening and a screen of the mat room. I have tried everything that the readme says to do but alas I must still be missing something. Altho is a pretty cool looking effect its not what im looking for. TIA, Spiritwolf Oh and clothing and everything else is rendering normal.
spiritwolf2000 posted Thu, 22 December 2005 at 3:32 PM
Guess I should also say im using P6
I know it has something to do with the Skin module but I cant seem to turn it off if I disconnect it it does other wierd stuff.
Message edited on: 12/22/2005 15:34
lmckenzie posted Thu, 22 December 2005 at 3:49 PM
No idea but it is indeed a very cool look.
dlfurman posted Thu, 22 December 2005 at 4:04 PM
I have the set, and I'll take a look....
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD space
dlfurman posted Thu, 22 December 2005 at 4:43 PM
I set up as you did with the default IBL SUN RIGHT light in Poser 6. I dont get that effect. However I did change light sets from the IBL to the "old" light array type set and got the effect you posted above. I say its the way this wonderful texture interacts with the lights.
unzipped posted Thu, 22 December 2005 at 5:13 PM
A few things I wonder about: The specular color is black, the specular value is 1.0000 and the highlight size is .3000 I doubt you want "black" highlights - try either setting the specular value to 0.0000 or change the color of the specular color and see if that doesn't address some of the darker areas of wierdness. For the lighter areas of wierdness I'd experiment with less bright colors for the sheen on the skin node. I'm just guessing, but these may be worth looking into. Unzipped
nruddock posted Thu, 22 December 2005 at 5:15 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2187315
Something that changed in the Skin node between P5 and P6 gives odd results with old lights (see linked thread).
pigfish9 posted Thu, 22 December 2005 at 10:29 PM
You might also try changing the sheen color in the skin node to a light shade of the texture color instead of the more caucasian peach default. The odd sheen on the texture in the render definitely has a peach hue.
drifterlee posted Fri, 23 December 2005 at 12:37 AM
I had a similar problem with Tawnie. The texture is older and not for P6. P6 does weird things with some older textures.
richardson posted Fri, 23 December 2005 at 5:33 AM
An easy fix would be to load a simple skin (V3with a simple color texture node). Then swap out the skin to Tawnie. Save Torso, head, teeth, eyelashes to Material library. Double click them onto all body parts...Back in poseroom, click on eyecolor from Tawnie matpose. Then save this as a new CR2. Now you have a simple texture. Or, In matroom...delete imagemap3 and skin node. Then set ambient and diffuse value to 1.00. Repeat or use library save (above). The alt diffuse node setup(Tawnie above) does not fly with all light setups.
Daventaki posted Fri, 23 December 2005 at 4:09 PM
I may have to do that Richardson or reinstall P5.... Beautiful as she is she wont cooperate. Ive tried IBL, tweaking the nodes. Everything everyone suggested didnt seem to help and some made it worse. Course I cant garentee im 100% correct on everything I did as I am just now getting into the learning phase of the material room. Thank You Everyone!!
nruddock posted Fri, 23 December 2005 at 5:14 PM
A screenshot of your Render settings might help spot the problem.
