Bisto opened this issue on Dec 23, 2005 ยท 9 posts
Bisto posted Fri, 23 December 2005 at 9:00 AM
Hi, Can anyone suggest a 3d horse model that is Free or low cost. I've looked at the milhorse but don't want to spend too much as I'm only trying to experiment with modeling and poser in general. I've looked on turbosquid,zygote and of course DAZ.Just wondered if anyone else can suggest anywhere else?
thefixer posted Fri, 23 December 2005 at 12:31 PM
Have you tried the DAZ Charger, relatively low cost and not too bad to use. There's a few images in my gallery with it if you want to have a look! thefixer, poser coord.
Injustice will be avenged.
Cofiwch Dryweryn.
Mystic-Nights posted Fri, 23 December 2005 at 12:40 PM
Attached Link: http://3dscience.com/free_3d_horse_model.asp
There is an open source horse available by Zygote. Not that it is not boned or rigged, so it is not poseable.randym77 posted Fri, 23 December 2005 at 9:29 PM
The 3dScience horse is the Poser 4 horse. Only not rigged for Poser. Not rigged at all, so you can't pose it. But if you want to learn to rig, check it out!
freyfaxi posted Sat, 24 December 2005 at 12:08 AM
If you're using poser..you already should HAVE a horse ? And there are lots, and lots of freebies availible for it as well ?
Message edited on: 12/24/2005 00:09
Bisto posted Sat, 24 December 2005 at 4:20 AM
Hi, Thanks for all the suggestions and comments. I'll try using the Poser 4 horse to start with a see how far I get. Thanks again.
Tiny posted Sat, 24 December 2005 at 7:02 AM
At planit3d.com there are very nice morphs for the P4 horse!
At the site select '/Downloads/Poser/Injections & Morphs'.
odeathoflife posted Sun, 25 December 2005 at 2:15 AM
so does zygote releaseing the mesh as a os mesh release the poser horse from (C) this is a little confusing ;~
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
randym77 posted Sun, 25 December 2005 at 1:42 PM
No. The open source horse is only the solid mesh. Basically, it's a horse prop. You would have to group and rig it to make it posable. If you do that, you can distribute it, but you can't distribute the Poser version.
