Cowboyuk opened this issue on Dec 30, 2005 ยท 6 posts
Cowboyuk posted Fri, 30 December 2005 at 3:25 PM
Message edited on: 12/30/2005 15:28
RyanSpaulding posted Fri, 30 December 2005 at 3:32 PM
Try reimporting your geometry. I had a similar "blue spot" problem that went away after I reimported.
-Ryan Spaulding
VueRealism.Com
Lyne posted Fri, 30 December 2005 at 6:24 PM
Ooooo! and I was just told by e-on to go get .09....eeek!
Life Requires Assembly and we all know how THAT goes!
firebolt posted Sat, 31 December 2005 at 9:44 AM
I had a problem like this with V5 Esprit a while back when my system got to its edge with a scene. When I finally managed (after some dozen crashes) to render, one element had those. They disappeared after I changed the lighting setup from Radiosity to Global Ambience and adjusted the lights accordingly.
Cowboyuk posted Sat, 31 December 2005 at 10:24 AM
Thanks firebolt, It seems that the spots only appear when using radiosity, it renders fine with GI...
bruno021 posted Mon, 02 January 2006 at 12:23 PM
Maybe because your radiosity quality settings were too low? If not, please report to e-on, this is not right, and should be fixed in the next update. I'm trying GR now too.
