Gwynhale opened this issue on Dec 31, 2005 ยท 12 posts
Gwynhale posted Sat, 31 December 2005 at 5:20 AM
There are hot threads in Lightwave forums about importing Blender fluid simulations as object sequences. The results are incredible! http://www.emphatik.com/3d/smdfluids.avi or http://jeremy.lwidof.net/downloads/lw_blender_fluids/jh_lw_blender_fluids2.zip As Blender is free, it would be also a great thing for Carrara. The question: how could we have an object that changes it's geometry in every frame (based on an .obj file sequence)? Any ideas? Is it possible at all? With a plug-in written for this purpose?
ren_mem posted Sat, 31 December 2005 at 6:21 AM
Yeah this was on the c forum.The pack of demos that you can download shows some awesome dynamics.I am sure some experimenting can be done.
No need to think outside the box....
Just make it
invisible.
falconperigot posted Sat, 31 December 2005 at 9:38 AM
Attached Link: http://www.benbus.co.uk/tmp/mercury.mov
They're impressive but you can do a lot with particles in C5. The animation at the link uses the mud preset as a starting point. Note: 500K mov file - Quicktime 7 required, and I won't leave it there forever because of my bandwidth limits!LCBoliou posted Sat, 31 December 2005 at 5:16 PM
I think C5Pro's particle system can come very close, if not match, the Blender fluid stuff?
ren_mem posted Sat, 31 December 2005 at 6:44 PM
Well I haven't seen the same results, but maybe. The distinct fluid look and flow.The soft body, rigid body, hair, and reuseable animation... stuff is great too. List goes on, but not sure how well all of it works. They really added alot.But man that interface loses me.I get to a point then oops.Just gotta admire the community support and devotion.
Just make it
invisible.
Gwynhale posted Sun, 01 January 2006 at 5:23 AM
Sure, one can try to do similar things with the Carrara particle system, but I found the "importing Blender fluids to Lightwave" idea interesting because it is a generic approach: create a changing geometry animation in one software (because you have better tools there for that particular job) and import it into your usual application, even if they don't talk natively at the animation level. The Lightwave users managed to do it with an .obj file sequence (and a few scripts), so the question still stands: can we do it with Carrara? E.g. is there a callback to some kind of plug-in during animation rendering where we could import the next frame geometry from an .obj file and replace the current one with the new one?
falconperigot posted Sun, 01 January 2006 at 7:56 AM
Yeah, I take your point. The best tool for the job is always the best way. It would be a nice thing to be able to do (and as I've just read on the SDK list, not impossible to do with a plugin). Let us know when it's available. ;-)
whkguamusa posted Mon, 02 January 2006 at 3:42 AM
Attached Link: http://fosterj.com/modules/xoopsgallery/cache/albums/album03/milkdrop.mov
You can use the blender fluids in Carrara pretty much the same way the XSI users are doing it. Export the fluid sim out of blender as a set of sequenced obj files, load them all into Carrara then show and hide them one at a time frame by frame. I followed the basic "drop in a cube" tut from the blender site and got this to render in Carrara http://fosterj.com/modules/xoopsgallery/cache/albums/album03/milkdrop.mov wayne k guam usafalconperigot posted Mon, 02 January 2006 at 4:09 AM
Nicely done. I'd been wondering if that would work.
AndyCLon posted Mon, 02 January 2006 at 6:29 AM
Attached Link: http://www.kawachi.zaq.ne.jp/kurozuka/akurodigital/
There is also the Metamesh addin from Akurodigital that has some good fluid like samples.AndyCLon posted Mon, 02 January 2006 at 7:51 AM
Attached Link: http://www.aceanim.com/FleaShow/Splash05a.mov
Here's an example of a splash using particles that I'm I've nade for my Flea Circus film.ren_mem posted Mon, 02 January 2006 at 6:37 PM
All nice examples.The cube fluid looks really good tho.
Just make it
invisible.
