JGC opened this issue on Mar 16, 2001 ยท 7 posts
JGC posted Fri, 16 March 2001 at 3:27 PM
I've been playing with 3D still images for a while now, so I'm no stranger to the software, but I've never tried animating anything. I'd like to make a short experimental trailer for a movie, so I need a program that works well with both characters and backgrounds. This is my dilemma: as an image artist I usually import a Poser character into a Bryce environment. This works great for stills, but it gets real complicated when you need to reposition a character (or at leats I think it gets complicated, if I understand how it works). So I'm trying to find out the best way to approach this project, and if there's one program that will make its realization the least painful. All advice is appreciated.
JKeller posted Fri, 16 March 2001 at 4:32 PM
You can do great animations with Poser and Bryce. But since Bryce can't handle character animation...you never actually import your characters into it.
What you do is:
This method does leave a bit to be desired...your Poser characters can't cast shadows on the Bryce environment. For a more robust (and more expensive) method, you could get LightWave or 3DS Max along with the Poser Pro Pack. With this you could import your Poser animations into environments you've created in LW or Max and render with their superior render engines.
JGC posted Fri, 16 March 2001 at 7:06 PM
Well, that gives me a place to start. Thanks for taking the time to respond.
mocap posted Fri, 16 March 2001 at 9:28 PM
Attached Link: http://server3006.freeyellow.com/3908/stats/hark.MPG
Hi this is an example of a poser animation with a bryce created background as described above by JKeller (1.5meg MPG)snazzy posted Fri, 27 April 2001 at 11:05 PM
Can you import Bryce environments (moving) into max or lw? Or do you have to make scenery there? I know PPP let's you export your Poser animations to there--wondering if you can do same with Bryce and have the two meet.
adh3d posted Sat, 28 April 2001 at 8:50 AM
No, you cant export a complete scene, the only thing you can export to max or lightwave is a terrain with textures.
snazzy posted Sat, 28 April 2001 at 1:27 PM
(That Konan approah looks very interesting). That's too bad that you go terrain by terrain. So pratically, you'd really want to design your entire enviro in these other apps (I guess there are plugins that speed that up). Bryce may head for the shelf if I go this route, save Konan.... Thanks for info.
