SUNNY6767 opened this issue on Jan 03, 2006 ยท 6 posts
SUNNY6767 posted Tue, 03 January 2006 at 10:05 AM
I import a wavefront.obj bodytexures are ok. But the hair is one lump and the poser 5 material isnt useable as a good tex. But there a so many reasons for me, make it a need to import the figure in Cinema. (Thinking know about to update to Poser 6...but this hairy thing must be cleared before..) Looks really ugly. So I hope someone can help with a view tips what to do?
stewer posted Tue, 03 January 2006 at 10:14 AM
Attached Link: http://www.reiss-studio.com/trade/productview/39/3/
The easiest most reliable solution is probably Body Studio.Dimension3D posted Tue, 03 January 2006 at 6:50 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=42060
With my plugin CinePoser LT, you can import the lines of Poser 5 hair as splines into Cinema 4D. Then, you can use a Sweep-NURBS to make them polygons for rendering.Dimension 3D - Poser Tools, Poser Props and Morphs, Cinema 4D
Plugins, and more
nruddock posted Tue, 03 January 2006 at 7:51 PM
Attached Link: http://www.skinprops.com/frb_main.htm
Riptide by spanki might also be useful.jelisa posted Sat, 07 January 2006 at 9:12 PM
Dimension3D, how would you do the sweep nurbs in c4d to convert the splines?
Dimension3D posted Sat, 07 January 2006 at 10:27 PM
Add a sweep nurbs to your scene. Turn off angle limit of the phong tag. Add a circle spline and use it as first child of the nurbs. Use a very small radius and no intermediate points (to reduce the number of created polygons). Then, add the spline as second child to the sweep nurbs. This may result in many polygons, but makes the spline visible for render.
BTW, when you export from Poser, turn on "show populated" for all dynamic hair, or Poser will export only the guide hair. And you should use a low value for verts per hair to reduce the number of spline points.
Plugins, and more
