beos53 opened this issue on Jan 05, 2006 ยท 4 posts
beos53 posted Thu, 05 January 2006 at 7:10 AM
Attached Link: http://webpages.charter.net/swieg123456/alldivx1.avi
I have been working on this since nruddock and svdl pointed me in the right direction. It is a pain in the ... to create and I still have a lot work to on it and to learn. This is what I did using the Blend node The only problem I had was the blend node on the Aiko figure, I set it up for the Torso and then applied it to the complete figure. Only the Torso worked, I had to go in and set the blend nodes for each part of the figure. I tried it several times, but still the same thing. Is there a way to set up the animation for the node for all parts of the figure? I hope I made myself clear Everything was done in Poser in 120 frames. It is about 256K and in DivX 6PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia
GeForce GTX 750 Ti
Bobasaur posted Thu, 05 January 2006 at 9:44 AM
I have no idea (I still use PPP). However, it looks very cool. when you get it figured out please post it so we can see the finished result.
justpatrick posted Thu, 05 January 2006 at 8:09 PM
I don't know if it's possible either, but what you have done there sure does look cool!
beos53 posted Fri, 06 January 2006 at 11:39 PM
Thank you for your comments. As far as I can tell and from what I have found out the animation settings don't carry over to the complete figure when copied from one part the applied to all.
GeForce GTX 750 Ti
