Subject: How can I combine two hairs?
julil opened this issue on Jan 06, 2006 ยท 9 posts
julil posted Fri, 06 January 2006 at 5:28 PM
This may be a bizarre question, but I'm wanting to combine two hairs, the history hair (set to base only) and Darkworld's Mistress Hair. But when I go to add one, the first one deletes. Is there a way to use them both on the same V3? TIA, Juli
richardson posted Fri, 06 January 2006 at 5:31 PM
Load the hair without a figure. Load 2nd hair and parent it to the 1st. Then save 1st hair back to hair library with both selected. You can lock the hair before you save, too.
julil posted Fri, 06 January 2006 at 5:34 PM
Thank you...I'll try this now! You guys are all great.
julil posted Fri, 06 January 2006 at 5:50 PM
Hmm, this didn't work. For some reason the parent is greyed out when I have the hair only loaded. I went ahead and saved both hairs, and the preview pic looked right, but when I went to load, it only loaded one.
julil posted Fri, 06 January 2006 at 6:12 PM
Okay, I putzed around with it, and it needs work, but I think I've got it. Thank you!
EnglishBob posted Fri, 06 January 2006 at 7:48 PM
Save one of the hairs into the Props library, rather than the hair library. Accept when it asks if you want it to be a smart prop. That prop hair can then be added to anything; it's only stuff from the hair library which removes any existing hair from the figure.
Message edited on: 01/06/2006 19:48
richardson posted Fri, 06 January 2006 at 8:42 PM
Ahh!... Thanks EBob.
julil posted Sat, 07 January 2006 at 12:08 AM
Yes, thanks EnglishBob! I was able to get the hairs on her head and looking the way I wanted, but no matter how I did the parenting, locking and unlocking, the hair stayed in the air and I was going to have to manually move the hair when I posed her. Juli
PabloS posted Sat, 07 January 2006 at 4:27 PM
~bookmark~
