Strelok opened this issue on Jan 08, 2006 ยท 5 posts
Strelok posted Sun, 08 January 2006 at 6:15 PM
http://img495.imageshack.us/my.php?image=17pv.jpg
So, here is the pic (my first dealing with vue at all), there are following questions, which i have:
2)There are some weird lines on the vue water just around all objekts.
How do I fix this stuff, anyone ideas?
thx
Strelok
Message edited on: 01/08/2006 18:17
randym77 posted Sun, 08 January 2006 at 10:14 PM
What versions of Vue and Poser are you using?
If you're using P6, I believe you still have to turn off external morphs (under Preferences). Vue can't read PMD files.
Not sure what you mean about weird lines. Are you sure that's not just the normal reflection/refraction you get when something is in water?
xantor posted Mon, 09 January 2006 at 1:09 AM
nruddock posted Mon, 09 January 2006 at 2:39 AM
All I can suggest is to try some slight variations on the material parameters.
The noise function for the Bump would be the one I'd try first.
Strelok posted Mon, 09 January 2006 at 10:04 AM
thanks, I'll be trying that today evening, the first problem is already solved, i got a quick answer at the vue forum and it works perfectly :) now going after the weird lines.
