fls13 opened this issue on Jan 10, 2006 ยท 13 posts
fls13 posted Tue, 10 January 2006 at 7:55 PM
After installing xp service pack 2, Poser crashes on me whenever I try to do anything in the parameter dials. I have already re-installed it and both P6 and the service packs. I have the same problem with P5, which is still installed on my HD.
This apparently happened with others, as I saw someone mention the same problem at another site, but that thread is no longer available. :O(
Message edited on: 01/10/2006 19:55
fls13 posted Tue, 10 January 2006 at 9:24 PM
Well now, P5 is working fine, but 6 still crashes when I try to do anything in the parameter dials. Can you believe it. 5 more stable than 6? Help!!!
nerd posted Tue, 10 January 2006 at 11:37 PM Forum Moderator
Try updating your OpenGL drivers. If that doesn't help try using the SreeD display mode.
fls13 posted Wed, 11 January 2006 at 12:08 AM
Tried both. No luck. :O(
nerd posted Wed, 11 January 2006 at 3:21 AM Forum Moderator
OK try this. Open the prefs and set The UI and Document to "Launch to Factory State" Exit and restart. Without opening a scene, see if it behaves now.
fls13 posted Wed, 11 January 2006 at 7:09 AM
It crashes when I hit the OK button on the general preferences dialog box.
Samhain74 posted Wed, 11 January 2006 at 9:20 AM
SP2 is the spawn of Satans mamma.I installed it and get a dozen or so different progs and games telling me "cannot find entry point" errors upon start up.There all .dll errors.Had to uninstall Bryce entirely.There is a list of known progs to have problems over at Microsux website,but i dont recall Poser being on that list.But SP2 is hell for sure.Good luck.
DigitalDreamer posted Wed, 11 January 2006 at 12:13 PM
I've had XP Pro SP2 on 3 machines and have had to take it off again - too many .dll errors. I'd remove it and go back to SP1 if it were me.
fls13 posted Wed, 11 January 2006 at 3:19 PM
Well, I did try to go back to the most recent restore point and was told it couldn't be done. Any other ways to do it? Thanks, Bill. :O(
Gordon_S posted Wed, 11 January 2006 at 7:27 PM
Sp2 trashed my previous computer's XP build when I loaded it. It wouldn't boot anymore. It would go into a "boot loop". There was no repairing it. I had to FORMAT: C . I rebuilt the XP load INCLUDING Sp2, and then had to reload everything else. Took a whole weekend, and lots of swearing. That was 14 months ago, and that computer has had NO problems since. (My daughter has it.) I found out later that it was the presence of an old SCSI driver in my build that caused the SP2 install to trash my build.
fls13 posted Wed, 11 January 2006 at 7:55 PM
It's ridiculous. I called Microsoft today, and got the sp 2 uninstalled (there were missing files, so I couldn't follow the "knowledge base" instructions. Still buggy and now other apps don't work. Think I'll just make sure I have everything I want properly backed up and re-install xp from scratch. Thanks for your help everybody.
Gordon_S posted Fri, 13 January 2006 at 11:54 AM
Yes, that's what I was thinking. Re-build the hard drive. The slick thing with Sp2, is that it won't LET you install bad drivers without asking you about it first. So, when you re-install your apps, it'll let you know of any serious incompatibilities.
fls13 posted Fri, 13 January 2006 at 1:05 PM
Well, be warned everyone. Neither Poser 6 OR 5 were ever buggy for me until this. Stay away from XP service pack 2. The XP re-install did work but what a time consuming nightmare.
