Forum: Carrara
Subject: Is there a way to convert a solid to a skinned model in Carrara or Hexagon?
nemesis10 opened this issue on Jan 19, 2006 ยท 7 posts
nemesis10 posted Thu, 19 January 2006 at 2:41 PM
I am working on a city that has that cool Ghost in the Shell distant city glow but my buildings are solid in cross section and I need thinness.
ren_mem posted Thu, 19 January 2006 at 7:50 PM
Well that is a little confusing.Mesh models aren't really solid.Really have to be more specific with some examples.Doesn't really sound like a modeling issue rather a texture, possibly volumetric light challenge.
No need to think outside the box....
    Just make it invisible.
nemesis10 posted Thu, 19 January 2006 at 10:59 PM
I have these shapes some of which are extruded from illustrator shapes. When a Boolean operation is performed on them or vertexes are deleted, the are hollow inside. I also have an obj I bought which when sliced or has vertexes deleted are solid all the way through. Is there a way to move from one to the other?
nemesis10 posted Thu, 19 January 2006 at 11:00 PM
ren_mem posted Fri, 20 January 2006 at 12:52 AM
Hex is probably more qualified for this...lot more options.I am new to subd so may not be too much help. Hex has a ton of tools.AI files can bring up several issues.May not have enough points or edges aren't connected so I am not surprised by that.Compund ai's seem to be a particular problem. Boolean's are a whole other topic with issues they can introduce(steer clear mostly).You can certainly alter just about everything on a model.They're really not solid tho so I still am not sure it will address a light effect.However, someone with more modeling experience can probably assist you with ai model issues because they can introduce some challenges.
ShawnDriscoll posted Fri, 20 January 2006 at 12:55 AM
Some programs turn objects into solids after a boolean cut. Some leave nasty polylines everywhere after a boolean cut. Some do booleans much better with NURBS objects rather than polygon objects.
ren_mem posted Fri, 20 January 2006 at 12:29 PM
Would Hex turn it into a solid. What option would you use to go between?
