Subject: Quick Rendering Question
AutoBot2000 opened this issue on Jan 20, 2006 ยท 4 posts
AutoBot2000 posted Fri, 20 January 2006 at 9:47 PM
I just updated myself to poser 6 and there was a quick thing i wanted to ask about the render compare feature. You know that when you render it kinda saves that image and then if you render again to compare to 2 images it saves that rander info, but is there a way to clear that so it doesnt store that info after time. So when i start a new project its not there again to get in my way so to say, Thanks for time
destro75 posted Fri, 20 January 2006 at 10:00 PM
If you go to Edit->Preferences, you will get a popup of upir general options. The first tab has a field on the lower right labelled: Max Cached Renders. This is the total number of renders that will be saved by Poser. For example, mine is set to 10. After 10 renders, the oldest ones get overwritten with each subsequent render. I found where they are stored once, but there really is no need to delete them manually. If it bothers you that much, just set the Max Cached Renders low, and that should solve that problem.
AutoBot2000 posted Fri, 20 January 2006 at 11:10 PM
Thanks i just wasnt sure how many render it would store and if i could chnage that at all, but i cant believe i didnt see if, i was looking for it too. Thanks agian
destro75 posted Sat, 21 January 2006 at 5:26 PM
No problem, glad to have helped!
