destro75 opened this issue on Jan 22, 2006 ยท 8 posts
destro75 posted Sun, 22 January 2006 at 8:56 AM
Hey all,
I don't know if this has been discussed in the past. I have a terrible memory ;-)
You can set up P6 (I don't know about previous versions since I don't use my old ones anymore) to open a totally blank scene, instead of with annoying James standing there with that dumb grin on his face.
If you go into your Runtime folder, and then into your Figures folder, you will find a file labelled default.figure. This is just a text file that you can open in Notepad. The last line should read:
readScript ":Runtime:libraries:character:James:JamesCasual.crz"
Just comment out this line with two slashes in front like the lines above it (//) Voila! No more annoying James when you start a new scene.
If you often do the same character, say Miki, or Vicky you can also change this line to point to the character you use so that you then load that one when you create a new scene.
Just figured I would pass along the info. I found it by accident last night, and thought people might appreciate it.
