bruno021 opened this issue on Jan 22, 2006 ยท 9 posts
bruno021 posted Sun, 22 January 2006 at 12:46 PM
wabe posted Sun, 22 January 2006 at 12:54 PM
Iwould ask technical support at e-on indeed. They will know best what it could be - and how to avoid it. Have you played with the overall material size a little? Maybe this could solve your problem. Maybe. In the meantime i would use the clone copier in Photoshop and correct that - is fastest.
bruno021 posted Sun, 22 January 2006 at 12:59 PM
Yeah, wabe, I change the overall size to 0.5, and the pattern is still there, just 50% smaller. Thanks for your quick answer.
wabe posted Sun, 22 January 2006 at 1:05 PM
I would go both ways. Make it really small - like 0.05 (because of the big size of the image) and see. And then go to a really BIG value - like 5 or 20 to see what this result in. Just a thought.
bruno021 posted Sun, 22 January 2006 at 1:43 PM
Values of 5 give aweful results, but very small values give better results, but the material gets very repetitive.
wabe posted Sun, 22 January 2006 at 1:55 PM
Maybe you can add a little noise to the function? Mathematical terms have a tendency to be repetitive i fear. Same calculation always give the same result - in a way.
bruno021 posted Sun, 22 January 2006 at 2:29 PM
Yes, I tried adding some cycling to the mat, and it looks a bit better. What would be interesting to know is: does this global turbulence is also added to the bump channel? I think not, since the pattern looks really flat.
wabe posted Sun, 22 January 2006 at 2:52 PM
Hard to say - but you can try it out and maybe disconnect the bump channels for a test. Then you will know.
bruno021 posted Sun, 22 January 2006 at 4:05 PM
Right, I'll do this tomorrow, need some sleen now, getting up tomorrow way too early for my liking! Thanks agin for your kind help.
