spedler opened this issue on Jan 22, 2006 ยท 12 posts
spedler posted Sun, 22 January 2006 at 3:41 PM
I've noticed something a little odd with a prop I'm working on. It's a small prop - about the size of a Poser figure's hand, say, but quite detailed. When rendered in my default setup with a single infinite light, it renders completely black, as if it wasn't being lit at all. The strange thing is that if there is a single figure (not another prop) in the scene, even if my prop is nowhere near it and not parented to it, it renders fine.
A little investigation shows that the render is as expected if:
In other words, the problem only occurs if an infinite light is used with depth-mapped shadows (and the depth map size doesn't make any difference). This must be related to a combination of prop size and light shadowing, but I can't explain why. It's nothing to do with reversed normals, I've tried that.
Does anyone know why this happens and if so what to do about it? (Using Poser 6 SR2, the prop is built with Cinema 4D.)
Many thanks,
Steve
Steve
