bga opened this issue on Jan 23, 2006 ยท 9 posts
bga posted Mon, 23 January 2006 at 8:14 AM
zollster posted Mon, 23 January 2006 at 6:07 PM
BenBischop posted Mon, 23 January 2006 at 8:13 PM
Try blending layers...
Sans2012 posted Tue, 24 January 2006 at 12:36 AM
How did you do it?
I never intended to make art.
bga posted Tue, 24 January 2006 at 4:47 AM
have you tried feathering your selection before cutting it? yes, i have How did you do it? i used the extract tool (filters)
tantarus posted Tue, 24 January 2006 at 7:44 AM
I was try to extract it but the background is really complicated, try to play with background eraser, it doesnt matter if you erase the part of the fur also. Just check the box next to the state before you start to erase in the history pallete, and use history brush tool (soft brush) to paint the fur back. Extract filter will somethimes do miracles and somethimes it will not do anything, it depends on the picture :) Tihomir
Open your mind and share the knowledge!
Quest posted Tue, 24 January 2006 at 1:34 PM
Use the stamp tool using aligned and use all layers options in a new transparent layer. Further, in the brush palette check on shape dynamics altering the size jitter option leaving it at 0% but setting the control option to fade and the jitter steps to 10 with a minimum of 0. Also check on airbrush. Then go near the edge of the tail using a soft brush size of about 27 pixels and start brushing back in your detail. You can further use the smudge, sharpen and blur tools. Here I only did the tail.
bga posted Wed, 25 January 2006 at 1:14 AM
Thank you to all for the quick response. Great hint..ty
tantarus posted Wed, 25 January 2006 at 6:48 AM
Nice technique Quest :) Tihomir
