Forum: Photoshop
Subject: filter_festival
apesnater opened this issue on Mar 21, 2001 ยท 6 posts
apesnater posted Wed, 21 March 2001 at 9:57 AM
I just wanted to show this one, it's base for a inteface I'm making. Any more suggestions?
DigitalDream#3 posted Wed, 21 March 2001 at 5:04 PM
Cool!
RomeoBoy posted Fri, 23 March 2001 at 2:12 PM
Great tunnel effect! I also love the texture on the floor/water. Only advice I can think to offer is to perhaps put some more blue (or white) in the water texture to reflect the surrounding walls/ceiling. Not sure if the white on water towards the back is to be a light source, or perhaps fog/mist... but if it is a light source, it should be a bit more prominent in the water texture. Keep up the good work! Joey
rockjockjared posted Mon, 02 April 2001 at 1:58 PM
that was made in photoshop??? Wow! I'm impressed! I just floated over from the Carrara area to see what was happening over here. I'm extrememly impressed with your work! I mainly use PS for creating texture maps and grayscales that I use in Carrara, nothing this complex. rockjockjared
vdallas posted Sat, 28 April 2001 at 2:03 PM
That's a great image... as you must know. :-) For PS, the lighting effects are great! The only thing that distracts me is the object at the bottom of the image. Is it a threshold... a step? What? However, whatever it is, it is a nice break in the rhythm of the picture. Everything else is wonderful. Using blending modes to place the water over the floorboards worked very well. How did you get those walls? Create a simple lattice template (airbrush & gradients?) and then distort it over & over again on different layers? Vince
apesnater posted Tue, 01 May 2001 at 5:02 AM
the walls were made in max,. see the start image I used. From there I just filtered & tweaked my way around in PS.
