CobraEye opened this issue on Jan 25, 2006 ยท 10 posts
CobraEye posted Wed, 25 January 2006 at 5:13 PM
Is it possible to use a black and white image as a mask to another image the same size. If so, is an alpha channel or a mask the technique to use?
retrocity posted Wed, 25 January 2006 at 8:35 PM
not sure what you're trying achive... can you post an example of sorts??
they say a picture is worth a thousands words.. especially when it's an explanation ;)
retrocity
aprilgem posted Wed, 25 January 2006 at 8:43 PM
Cobra, yes and yes.
CobraEye posted Wed, 25 January 2006 at 10:26 PM
I want the blue layer to have a transparent gradient round hole so it shows the round picture underneath it. How to I use the black and white image to make that effect?
So far I get strange results.
aprilgem posted Thu, 26 January 2006 at 12:16 AM
Create a new image the same size as your blue and b/w images. Place your round picture in the center. Place the blue image as a new layer over your round picture. Create a new Alpha Channel. Copy the black and white image. Paste the black and white image into your new Alpha Channel. Ctrl-select your Alpha Channel so that you get the crawling ants. Go to your blue layer. Select Layer > Add Layer Mask > Hide Selection.
archdruid posted Thu, 26 January 2006 at 9:43 AM
Crawling ants?? LOVE it...... that's the best description yet. Lou.
"..... and that was when things got interestiing."
aprilgem posted Thu, 26 January 2006 at 11:48 AM
Yep. I wish I'd thought of it first, though. :)
CobraEye posted Thu, 26 January 2006 at 1:36 PM
That worked. So just to clarify: I am using the alpha channel as a mask by following these steps? Thanks
aprilgem posted Thu, 26 January 2006 at 1:56 PM
Actually, in this case, it's more like a holding area. I just had you use the alpha channel because it's easier to paste the black and white image to it and so you could more easily make a selection with the channel before creating the actual mask. The mask, on the other hand, is on the layer itself. It's kind of like an alpha channel that belongs only to that layer and that goes wherever the layer goes. :)
thundering1 posted Fri, 27 January 2006 at 3:22 PM
