chippwalters opened this issue on Jan 27, 2006 ยท 13 posts
chippwalters posted Fri, 27 January 2006 at 12:39 AM
The subject says it all. I'm just wanting to create a procedural gradient texture material so that if I apply it to an object it will go from one color to another. TIA, Chipp
bruno021 posted Fri, 27 January 2006 at 2:59 AM
That's pretty easy, but you're not saying which version of Vue you have. Anyway, this should work in 5 Esprit to 5 Infinite: In the advanced material editor ( might work in the basic, but I never use it), right clich the defaut colour gradient, and click edit, or just Ctrl-click it. Then you just have to click on any part of the gradient, and add a colour. each new colour has a handle at the bottom, that you use to change the position of your colour inside the gradient. Use as many colours you want. When you're done, click ok, that's it.
Polax posted Fri, 27 January 2006 at 4:11 AM
bruno021 posted Fri, 27 January 2006 at 4:16 AM
And to be sure all colours will appear on your material, add a filter to the color production function, in the function editor, choose brightness-contrast, lower the brightness in the minus, and go for a +2 or more for the contrast. Learned this from the procedural terrain tutorial from C3D.
chippwalters posted Fri, 27 January 2006 at 4:30 AM
Yep, I get it all but how do I create the color production function? Just an explanation will do. Thx (I'm using Vue-I)
Polax posted Fri, 27 January 2006 at 4:53 AM
Add Noise Node/Math Pattern to color production. You can choose Saw Teeth, Sine Wave etc.. , zero the axis you don't need. e.g: X and Z, keep Y then play with scale and origin of function to fit your needs. Of course you could also use a bitmap gradient in a texture node. Hope that helps :)
chippwalters posted Fri, 27 January 2006 at 4:58 AM
Great! Helps a lot. Thanks :-) I've been playing around all evening with the add color node function and just couldn't get it to work. Thanks again :-)
chippwalters posted Sat, 28 January 2006 at 6:53 AM
Attached Link: http://http://www.altuit.com/webs/altuit2/VueLab/CreatingaGradientMaterial.htm
![grad88.jpg](http://www.altuit.com/webs/altuit2/VueLab/grad88.jpg)Here's a tutorial on creating Procedural Gradient Textures using a mixed technique of settings. I particularly like the ease with which the gradient texture can be rotated on any object.
Thanks to the many here and on e-on's website who have helped me better understand how to manage gradients in the filter editor.
best,
Chipp
bruno021 posted Sat, 28 January 2006 at 12:00 PM
Great tutorial, it will be very useful to those who are afraid of the function editor. Oh, and thanks for the credits too, wasn't necessary, but very appreciated.
Peggy_Walters posted Sat, 28 January 2006 at 12:14 PM
Hi Chipp,
I'd like to see the tutorial, but I am getting a page not found... Did your bandwidth get exceeded?
Peggy
Message edited on: 01/28/2006 12:15
LVS - Where Learning is Fun!
bruno021 posted Sat, 28 January 2006 at 1:27 PM
No, had the same problem: Chipp copied and pasted his url in the preformatted box here, which already contains the http://, so you have the http thing twice, and the page can't be found. Just delete the double http, and you'll get to the page.
chippwalters posted Sat, 28 January 2006 at 6:10 PM
Attached Link: http://www.altuit.com/webs/altuit2/VueLab/CreatingaGradientMaterial.htm
OOPS. here's the correct URL!
Peggy_Walters posted Sun, 29 January 2006 at 12:40 PM
Thanks! Great tutorial! Peggy
