chinnei opened this issue on Jan 31, 2006 ยท 4 posts
chinnei posted Tue, 31 January 2006 at 5:48 PM
I've made changes to V3 catsuit cr2 by replacing "Figure 1" and ":1" to "Figure 2" and ":2" except for JCM's. It now works fine without any usual pokethroughs when I apply a pose in my Poser6.
My question is, why can't I get this same effect when I create a new clothing out of the catusuit (i.e. cutting off the sleeves or legs by using grouping) and applying the above method? I used setup room and applied either the modified catsuit figure or the original figure to the newly created prop. However, either case, I get the same poke through that I get with the original catsuit figure.
Any ideas as to why I can't get this to work?
