HopsAndBarley opened this issue on Feb 03, 2006 ยท 9 posts
HopsAndBarley posted Fri, 03 February 2006 at 5:08 AM
Hi, I just needed to make a quick bit of 3D text for a project and opened up one of the logo-scene wizard preset things. I picked the HDRI one. It's just about exactly what I needed, added a little reflection on the ground, increased the ambient light a tiny bit.....I would like to get rid of the shadows though and therein lies my problem. I turned off cast (and receive) shadows on both the text and the infinite plan but I still get shadows...? Am I missing something here? Thanks H&B
Sans2012 posted Fri, 03 February 2006 at 6:59 AM
It sounds like you need to stop the light source from projecting shadows. Not 100% but maybe;) Michael; not so familiar with Carrara:)
I never intended to make art.
falconperigot posted Fri, 03 February 2006 at 7:00 AM
I don't think you can switch shadows off for SkyLight. You could do a couple of things depending on what you are after. Switch off SkyLight in the Render room and push up Ambient Light so that there is enough light on you scene (normally you would have no ambient light at all in GI). Or delete the plane so that it's no there to receive shadows.
Kixum posted Fri, 03 February 2006 at 7:23 AM
I think falcon is right on this one. If you're getting light from the GI engine, the objects will iterfere regardless of the shadow settings. "Flooding" the scene with a little extra ambient is a neat idea and may do the trick. -Kix
-Kix
HopsAndBarley posted Fri, 03 February 2006 at 7:25 AM
THanks guys, I'll give your suggestions a try. Though I can
anastasis20 posted Fri, 03 February 2006 at 7:53 AM
Have you tried switching off shadows in the render room as well? That should do what you want - not render any shadows at all.
ren_mem posted Fri, 03 February 2006 at 2:08 PM
Anastatis20...that won't work here.
No need to think outside the box....
Just make it
invisible.
anastasis20 posted Fri, 03 February 2006 at 4:33 PM
How come? (if anyone knows) I've switched shadows off most of Carrara's other light types and gotten skylight rendering to work as I wanted. It would be interesting to know, having just tried it for myself. I've never switched shadows off an hdri render before because they generally aren't too obvious compared to the other lights in Carrara.
ren_mem posted Fri, 03 February 2006 at 8:09 PM
I am guessing here, but it simply seems that those options aren't tied to the render options. There is no unique GI option altho a transparency one. And the raytrace option isn't tied to that either.All I know is just disabling shadows by itself doesn't work here.
Just make it
invisible.
