Subject: Poser 6...Lights Out???
Chippsyann opened this issue on Feb 05, 2006 ยท 3 posts
Chippsyann posted Sun, 05 February 2006 at 6:17 PM
Has anybody ever run across this problem in P6? I was setting up an image,then I started adjusting my light setup and then they all turned off. I tried to reload another preset light but, they where turned off as well. "What happened, what did I do? Other then reverting the image, how do you turn the lights back on?
Acadia posted Sun, 05 February 2006 at 6:28 PM
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?forum_id=43&ShowMessage=184683
They aren't "turning off". Poser 6 is weird and only will preview a total of 8 lights. So if you have more than that on the little globe, the lights show as almost black in the pose room. Though they do render ok.
Before I apply any lights now I go to Python and "Utilities" and delete all lights, then apply the new set. If you are using lights meant for Poser 4 or Poser 5, you will have dark, almost black previews in the pose window.
I had such trouble that someone pointed me to RDNA where others complained about the same issue last summer. I was so beside myself that Olivier was kind enough to do up a tutorial for me to explain IBL and give me some templates. You can find the tutorial here:
Message edited on: 02/05/2006 18:35
Chippsyann posted Sun, 05 February 2006 at 6:37 PM
Thanks Acadia, this was my only beef with P6. It's been about 4 months since I last tried P6, (same problem) I'll check this link out, thanks.
