AlteredKitty opened this issue on Feb 08, 2006 ยท 12 posts
AlteredKitty posted Wed, 08 February 2006 at 5:53 PM
amacord posted Wed, 08 February 2006 at 6:08 PM
set the diffuse color to black. maybe you want to increase specular value.
templargfx posted Wed, 08 February 2006 at 6:26 PM
best method for creating chrome is to plug the reflect node into the ALTERNATE DIFFUSE slot, and set the standard diffuse to black and the diffuse value to 0. this will give you a very clear and crisp reflection. to do silver, set the alternate diffuse color to a meduim grey (with the reflect node still plugged in, and set the standard diffuse amount to around the .4 mark. set the standard diffuse color to a blue-grey combo. or a goldish color (for gold Obviously)
TemplarGFX
3D Hobbyist since 1996
I use poser native units
AlteredKitty posted Wed, 08 February 2006 at 6:59 PM
Thank you both very much :) May I just ask, is the 'Reflect Node' the box which says "Reflection Image" in the TRH corner of the pic above? This is what I plugged in to the Alternate Diffuse and got much better results.
anxcon posted Wed, 08 February 2006 at 9:03 PM
no, thats an imagemap node (load a pic to use) place a new node, raytrace > reflect
Jules53757 posted Thu, 09 February 2006 at 2:26 AM
RDNA has metallic materials in their freestuff, give them a try.
Ulli
templargfx posted Thu, 09 February 2006 at 4:35 AM
The way you have the material setup above, it is not a true reflections, it is using the image in the reflection image node to simulate the reflections without actually needing to use system resources to calculate the reflection.
in other words, whatever is in that image is "wrapped" around the model to give the illusion of a reflection.
the lighting->ray-trace->reflect node will actually reflect the things in your scene. so you will see the character reflected in the object.
a thing to note with the reflect node.
you will notice when you add it that it has a background color section. what this is for, is when it reflects things, if there is nothing to reflect, it will treat the area that has no reflection as if its reflecting a surface with this color on it (does that make sense?) so, what you want to do, is attach that sphere map (that has the reflection image connected to it) to the background color section of the reflect node (and change the color to white). then any part of the object that has nothing to reflect will use this image as the reflection.
FINALLY, if you use the above method, you need to plug the reflect node into the ALTERNATE DIFFUSE on the POSER SURFACE, NOT the reflect section, otherwise the attached nodes to the BACKGROUD COLOR section will be ignored.
Message edited on: 02/09/2006 04:38
TemplarGFX
AlteredKitty posted Thu, 09 February 2006 at 6:37 AM
Thank you all so much for your time and help, I've really learned a lot from this. ali x
kobaltkween posted Thu, 09 February 2006 at 11:35 AM
templargfx - i think we could all get as much out of you doing a general reflective materials thread as we have your car paint ones. i know i'd be very interested. not just metals, but wet surfaces like the one in your parking lot pic.
diolma posted Thu, 09 February 2006 at 4:54 PM
Lilybelles: What is washing your image out is the diffuse colour set to White, with a value of 1. Try changing it to black (and/or value 0) and see if that helps:-) Also, remove the specular value (set it to black, too.) These nodes (and the ambient channel) are added to the colours that are produced by reflections. So they can be used to tint/bias/subtly alter reflections, but must always be used in very low amounts for very shiny materials, otherwise they overpower the reflections.. Cheers, Diolma
templargfx posted Thu, 09 February 2006 at 7:14 PM
OK cobalt, when I get some time (im making an ai for a custom warcraft 3 map this very second) I will do up a general reflection thread and put up all the info that I know about it! diolma : your kindof right, when a reflect node is plugged into the reflect section of the poser surface, what it does is calculates the objects diffuse, then adds the reflection on-top changing the color of the current pixel according to the reflection up to a maximum of 255,255,255 (white). this is why, if you plug the reflect node into the alternate diffuse, you can get over-bright coloring on the object, because the current pixels color is a combination of the diffuse color PLUS the alternate diffuse (reflection) color, but is not capped at 255,255,255 (white)
TemplarGFX
kobaltkween posted Thu, 09 February 2006 at 8:53 PM
thanks so much!
