Subject: a Mat pose file for a Prop? HELP!
GothKurlz opened this issue on Feb 10, 2006 ยท 6 posts
GothKurlz posted Fri, 10 February 2006 at 12:07 PM
Pleaseeeeeee, is there a way to make a pose file for a prop? and if so how? i'm running P6. any help is appreciated it! thanks so much!
Little_Dragon posted Fri, 10 February 2006 at 12:12 PM
From the Material Room, you could simply save a material collection to the library. Poses usually won't work on props unless they're parented to a figure.
lesbentley posted Fri, 10 February 2006 at 1:47 PM
You can use the free utility "MAT Pose Edit", to make the MAT file.
Normally a pose file won't work on a prop unless the prop is parented to a figure, but if you do need to apply a pose to an un-parented prop, there is a way.
Open the pz2 in a text editor. Replace "prop " with "actor ". See below:
{<br></br>version<br></br> {<br></br>   number 3<br></br>    }<br></br><strike>prop box_1</strike><br></br> box_1<br></br>        {<br></br>   material Preview<br></br>            {<br></br>           KdColor 1 0.501961 0.501961 1<br></br>               KaColor 0 0 0 1<br></br>             KsColor 1 1 1 1<br></br>             TextureColor 1 1 1 1<br></br>                NsExponent 10<br></br>               tMin 0<br></br>              tMax 0<br></br>              tExpo 0.6<br></br>           bumpStrength 1<br></br>              ksIgnoreTexture 0<br></br>           reflectThruLights 1<br></br>         reflectThruKd 0<br></br>             textureMap ":Runtime:Textures:Ground Default Texture.tif"<br></br>                           0 0<br></br>         bumpMap NO_MAP<br></br>              reflectionMap NO_MAP<br></br>                transparencyMap NO_MAP<br></br>              ReflectionColor 1 1 1 1<br></br>             reflectionStrength 1<br></br>                }<br></br>   }<br></br>}
This method of replacing "prop " with "actor " works for any type of pose (pz2).
Note that a figure must be present in the Poser scene before any pose file will work, but the prop does not need to be parented to it. Also note that a pose for "someProp_1" will not work on "someProp_2".
Richard T posted Fri, 10 February 2006 at 1:55 PM
Just apply the materials you want to the prop and resave the prop with a new name. It is effectively a mat file except it lives in your props folder. If the geometry of the prop is external the new file will be approx thew same size as a "mat file". You may need to create a .png file for the library pic depending upon what version of Poser you are using. Richard
lesbentley posted Fri, 10 February 2006 at 2:05 PM
"It is effectively a mat file except it lives in your props folder."
I beg to differ. The purpose of a poze file is to inject new data into an item that is already loaded in a Poser scene. A pp2 can't do that.
GothKurlz posted Fri, 10 February 2006 at 3:28 PM
ty for all the help :) will give it a go!
