Subject: Making INJ Poses
Parthius opened this issue on Feb 11, 2006 ยท 3 posts
Parthius posted Sat, 11 February 2006 at 3:47 PM
I need to convert a V3 full body obj file to all the body part delta files, etc and INJ/REM files. Last time I played in this area, Pozers Little Helper was the only thing I could find that would map a new obj into one of the V3 hidden morph channels and generate all the required files. Is it still the way to go, or are there alternatives that I should be aware of? Thanks! Parthius
EnglishBob posted Sat, 11 February 2006 at 3:58 PM
You can do it manually, but PLH is easy to use - unless you have some reason not to use it, I'd say stick with it...
Parthius posted Sat, 11 February 2006 at 4:41 PM
Thanks, I was mainly curious as to whether there were any new alternatives. It was/is very easy to use.
