ilr opened this issue on Feb 13, 2006 ยท 4 posts
ilr posted Mon, 13 February 2006 at 1:30 AM
Hi Comparing to other poser figures like V3 - is Satoko smaller? or bigger? or it's of the same size? In other words - can I use Satoko for example with V3 in one scene without changing figure scale? thank you
William posted Mon, 13 February 2006 at 1:32 AM
It's the same scale but shorter than V3, petite would be the word. Maybe 2/3 V3's height.
ilr posted Mon, 13 February 2006 at 1:37 AM
thank you. and what about joint parameters/settings? everything working well? comparing to V3 again?
William posted Mon, 13 February 2006 at 12:03 PM
Not as bad as V3 at some joints. Others have about the same degree of problems. If you've seen the product shots you may have noticed that the figure has legs that are large in proportion to it's body...which I found a change to long-legged V3.
