mystmaiden opened this issue on Feb 14, 2006 ยท 6 posts
mystmaiden posted Tue, 14 February 2006 at 8:05 PM
I'm very new to using Poser and the other night I saved two renders without choosing where they went. I can't find them with search because I didn't record the names accurately :( So does anyone know where they may have saved to as a default?
ashley9803 posted Tue, 14 February 2006 at 8:19 PM
Probably somewhere in your Curious Labs folder or possibly in My Documants. Renders are by default called "Render .." followed by a number starting from 1. You should be able to search for a file called "render" Or if desperate search for the file format, BMP or JPG.
ockham posted Tue, 14 February 2006 at 8:33 PM
If you're using Poser 6, the last 10 renders are preserved in an 'undisclosed location', whether you consciously save them or not. Search for the folder PoserRenderCache and you'll get there. These files won't show up in a search for *.BMP because they're given the TMP extension, but they are actually BMP files.
billy423uk posted Wed, 15 February 2006 at 3:23 AM
if you open poser and try and save something the way you did before it should save it to the same place as last time (i think) anf you should be able to find it. billy
Jimdoria posted Wed, 15 February 2006 at 9:29 AM
Have you looked on the Start Menu under Documents or Recent Documents? They might be there, too. If any of the files shows up in the recent documents list, you can right-click on it, choose Properties from the popup menu, and when the Properties dialog appears, click the "Find Target..." button. A window will open up showing you the location of the file. If you don't have a Documents or Recent Documents list, right-click the Start Menu button then click Properties from the popup menu. When the Properties dialog appears, click "Customize..." then choose the Advanced tab. At the bottom is an option that says "List my most recently opened documents". Put a check mark next to that, then OK all the way back out. - Jimdoria ~@>@
radstorm posted Wed, 15 February 2006 at 12:40 PM
click on documents just below programs in the start thingy..it usually tells you what your most recent works were :0) You can also find a folder called "Recent' in document and settings (may be hid and you will have to do a "show hidden files and folders" in folder options)and see lots of stuff. I'm probably just repeating what everyone else is saying..LOL
