ghelmer opened this issue on Feb 19, 2006 ยท 10 posts
ghelmer posted Sun, 19 February 2006 at 11:18 AM
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
ghelmer posted Sun, 19 February 2006 at 11:21 AM
To clarify... this has been happening on V3 and Aiko 3 as well and it's not just a Miki thing... OT I quite like Miki! She's so fine, she's so fine she blows my mind, HEY MIKI! HEY MIKI!! LOL!! Sorry! I'm stuck in the 80's!!
G
Message edited on: 02/19/2006 11:21
The GR00VY GH0ULIE!
jt411 posted Sun, 19 February 2006 at 11:56 AM
Did you have the "Light through transparency" button checked in your render options? (Why did you make her boobs so small?)
ren_mem posted Sun, 19 February 2006 at 2:25 PM
LoL, omg. 2 things, Must have alpha maps in the channels, then must have both options for light thru trans turned on, if you are using GI.(Both are in render room, one at the top and 1 under GI area below.)
No need to think outside the box....
Just make it
invisible.
brycetech posted Sun, 19 February 2006 at 7:54 PM
unless you draw arrows (like in the pict)..no one would look at her head anyhow... lol
ghelmer posted Mon, 20 February 2006 at 8:55 AM
The GR00VY GH0ULIE!
ren_mem posted Mon, 20 February 2006 at 12:22 PM
The manual helps, however, I doubt it is updated properly...this has been a small issue. It does have some poser tips in transposer.pdf and I think the other one. The change in 5.03 added this as part of the GI transparency issues that had been happening, then they corrected the overlighting in 5.04 When you don't use GI you obviously don't need the GI option (it will be greyed out).
Just make it
invisible.
charlesb posted Fri, 24 February 2006 at 12:29 PM
Yes we added the "Light through Transparency" option for the GI in 5.0.3. The reason is that we had fix the alpha channel for the GI and that in some cases it can lead to extremely long rendering time without any real benefit. (Try rendering trees with Alpha masked leaves and global illumination, each rays for indirect lighting can go through thousands of leaves...) So I decided to turn it off by default to keep the fast rendering.
bluetone posted Mon, 27 February 2006 at 6:04 PM
Thanx Charles! :D Now... can you fix the problem with the second pic? Seems to fade out right below the clavical for some reason.... ;)
charlesb posted Mon, 27 February 2006 at 6:19 PM
I don't think that's a bug, it is probably just a lighting issue...
