eelie opened this issue on Feb 19, 2006 ยท 5 posts
eelie posted Sun, 19 February 2006 at 7:44 PM
Hi there all, :o) I'm new to this forum altho I've been on R'osity for a couple of years in others. Anyway, I'm having a stupid problem and I'm clueless. ;o) I'm using Photoshop CS (v8.0). I have it both at work and at home. I've recently been starting to experiment with paths and using them to make, basically, lines. At work, I can use the pen tool and click for the start and stop points, add points where I need them, move the path around, then use the stroke function and fill just the line. It's that simple. Well, using the very same program at home and trying to do the same then, as soon as I add the first point and move it, the silly thing closes the start/stop points and fills the selection. Now, frankly I don't remember it ever doing this at work and if it did, I don't remember adjusting any settings. Thinking that's what's needed to fix it, I've been looking thru everything I can find but I can't find anything that will keep it from doing this. I'm trying to simply draw lines that have multiple "waves" in them and this fill thing is getting quite irritation! ;o) Can someone tell me how to fix this? Please? Pretty please?? :o) Susan
nio103 posted Sun, 19 February 2006 at 9:49 PM
The settings of the pen are at the top. ill explain some more if you cant find it. :)
eelie posted Sun, 19 February 2006 at 10:43 PM
Uh, no, that's ok. I found it. Sheesh....I must be more blonde than I thought. ;o) Thanks! That's what I needed...just a point in the right direction. :o)
Quest posted Mon, 20 February 2006 at 1:56 AM
Eelie, LOL...we're not all born knowing everything...thank you for asking the question that made many think!
Jack Casement posted Tue, 21 February 2006 at 6:26 AM
The same thing had been happening to me and I hadn't a clue how to fix it. So many thanks for posting it.
