hogwarden opened this issue on Feb 21, 2006 ยท 20 posts
hogwarden posted Tue, 21 February 2006 at 5:08 AM
PBooost II (2.0.1.14) full package and upgrade.
PBooost II is a library manager for Poser... and a whole lot more. Designed from scratch for both professional and hobbyist Poser user alike, PBooost II offers a straightforward and clear Explorer-style interface for optimum workflow.
The PBooost Bank System allows content in each library category to be grouped into banks to reduce the number of items shown in the Poser library tab. You only see the content you want! Fully customisable Bank Groups allow you to group banks across the categories to further improve your workflow.
PBooost II can fully replace the Poser library tab for figures, hair and props. Items, even many at once, can be loaded directly from PBooost II into the running Poser scene in all Poser versions thanks to Hogsoft's innovative P4PyE technology. You can even drag files from PBooost and drop them into Poser!
What makes it so powerful and easy to use:
Designed to be fully compatible with Poser 4, 5, 6 and Propack.
Explorer-style browser interface with full drag/drop and cut/copy/paste functionallity makes it really easy to organise your library just the way you want it.
Thumbnails shown for content (rsr or png). One thumb represents the content file, thumbails and any other associated files.
Load figure/hair/prop content straight into the Poser scene with a double-click
Find Content tool makes it easy to search your runtimes for content.
Multiple runtime support! Many libraries can be viewed simultaneously, each open in it's own PBooost II window.
Switching banks is as simple as clicking on a bank's red dot.
Function to switch to all banks with that name across all categories in one click.
Library Quick Switch panel gives even quicker access to switching banks.
Folder Lock Wizard eradicates folder locks through a clear checklist of known causes.
All functions quickly available with a right-click.
Convert selected content into a new bank in one click.
Bank Groups give you the power to switch many banks at once in a single click.
Preview content or open it in your favourite text editor from the browser.
Content Properties dialogue shows you information on content or content folders.
Automatically checks content to see if there are any items in the wrong categories or with incorrect extensions when you move/copy files.
Clear and concise windows help file included.
The installer includes the Hogsoft Hub which, in addition to being a central point to access utilities, programs, links and documents, gives you a mini PBooost Remote Control so you can switch banks anytime... without even having to open PBooost!
Extra tools and features:
Loader Plugin system allows PBooost II to be expanded to pre-condition files while they are being loaded into Poser**.** **
** Content Plugin system expands PBooost II to open/edit files in specialised utilities.
Tool Plugin system expands the tools and functions of PBooost II in a modular way.
Installs a Python script into Poser 5, 6 and Propack Python menu palette to allow launching of PBooost II from Poser.
Check content to see if there are any items in the wrong categories or with incorrect extensions.
Automatically checks and repairs library problems which could occur after windows re-install or system restore.
The main interface:
The right-click menu::
Setting up bank groups:
Hogsoft Hub PBooost remote control:
The folder lock wizard (Simulated display... you'll never see all these problems reported at once!)
hogwarden posted Tue, 21 February 2006 at 5:10 AM
Act fast!... For the first 7 days after PBooost II is launched at Renderosity, when you purchase PBooost II (full or upgrade) you can get it's new Figure Independent Injection plugin, worth $10, absolutely free!
To get hold of your free copy of the FII plugin, simply download the little program ** here**. When you have installed PBooost II, run this little program and it will link you to your free download.
Figure Independent Injection plugin (1.0.0.2) for PBooost II.
This utility is a tool plugin for Hogsoft PBooost II and requires PBooost II to operate.
**What is Figure Independent Injection and what can it do for me?
** Millennium 3 characters (such as Daz Victoria 3, Micheal 3 and the Freak) use a system called Morph Injection to insert/remove different morphs into the figure by the use of morph injection poses. The characters also contain Full Body Morphs (FBMs). These appear as dials in the BODY of the figure and control morphs in many body parts at once. Additionally, the characters may contain Joint Controlled Morphs (JCMs) which allow movement of one body part to affect morphs in others. This system works extremely well when there is only one figure in the scene but, due to idiosyncrasies within these Daz products, if two or more Millennium 3 characters are needed with different morphs, then the FBMs and JCMs stop working: Any morphs injected into Figure 2 take their FBM and JCM control from Figure 1. This means that, in order to give the characters different morphs, you must forget about the FBM dials and JCM and tweak each dial on every body part to the required extent. This can take many more hours than if the FBMs just worked properly. Well, now they can!
Figure Independent Injection describes a discovery by Maveris, developed and tested by lesbentley and layingback, whereby the morph injection files themselves (those files stored in the libraries!Daz folder) are subtly altered to allow multiple figures to control their own FBMs and JCMs.
When the Figure Independent Injection plugin is installed, it creates for PBooost II an FII copy of the !Daz injection folders which can be switched in/out just like any other PBooost bank. When the new PBooost II FII injection bank is switched in, any Millennium 3 figures loaded into poser will be free from the single figure FBM and JCM limitations explained above.
Easy to install plugin. Just run setup.exe and then start PBooost... choose "initialize" from the PBooost tool plugins>FII menu. That's it!
Switching your injection folders from normal to FII is as simple as one click!
Install, initialise and forget... if you always want FII to be active.
No more hand-editing loads of files or running complex scripts to get FII flexibility.
No Python required: works in all Poser versions.
Doesn't alter your existing injection files at all... it creates it's own special FII copies.
The PBooost II library tree now shows the default !DAZ and FII injection banks:
Philywebrider posted Tue, 21 February 2006 at 7:20 AM
I tried to find PBooostII in your renderosity store, but all I got was PBooost 1.4, and CRPro II. What am I doing wrong?
hogwarden posted Tue, 21 February 2006 at 9:37 AM
Sorry Philly... I pre-empted it by a few hours:) As soon as it is available I'll post the links above. H:)
Philywebrider posted Tue, 21 February 2006 at 9:46 AM
Thanks, much appreicated.
mathman posted Tue, 21 February 2006 at 2:32 PM
Is there any sort of discount for those of us who have purchased PBooost v1 ?
arrow1 posted Tue, 21 February 2006 at 2:53 PM
They seem to have the thumbnails around the wrong way! The upgrade is dearer than the full version.
Custom built computer 128 gigs RAM,2 Terrabyte hard drive, NVIDIA RTX 3060 12 Gig, Intel i9, Dual Dell Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terrabyte SSD Hard Drive plus 1 Terrabyte Hard Drive,3rd Computer intel i7,64 gigs ram, Graphics Card NVIDIA GeForce GeForce 1660 Ti 6 Gig,1 Terrabyte Hard Drive, OS Windows 10 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus Lenovo Laptop 64 Bit,12 gigs Ram.Intel i7 chip.Windows 10 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.22, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Philywebrider posted Tue, 21 February 2006 at 2:59 PM
Please correct the prices, I'd like to purchase the full package and I don't want to cheat you.
darken666 posted Tue, 21 February 2006 at 3:19 PM
I IMed and emailed Hogwarden, hopefully he'll see them soon and get it corrected
garblesnix posted Tue, 21 February 2006 at 4:28 PM
I remember having to do some kind of test for an earlier version of PBoost on my machine to test compatability, and I was found wanting. Has the newer version done away with this necessity?
mathman posted Tue, 21 February 2006 at 5:56 PM
oops ... re my earlier post (#7), it helps if I read the thread properly to start with, doesn't it ... blush
mathman posted Tue, 21 February 2006 at 6:05 PM
I still don't see it in the Marketplace ??? ... dying to know what the upgrade price is.
Philywebrider posted Tue, 21 February 2006 at 7:11 PM
I think the full price is $41.00, and I think the upgrade is $10.95. They were in the market place, but the prices were transposed, so they removed them to correct them.
Philywebrider posted Tue, 21 February 2006 at 7:12 PM
I remember having to do some kind of test for an earlier version of PBoost on my machine to test compatability, and I was found wanting. Has the newer version done away with this necessity? I like to see an answer on this.
hogwarden posted Mon, 27 February 2006 at 6:34 PM
Hi Philly... Yes, the problem is solved. The new PBooost II Folder Lock Wizard will help to quickly irradicate any problems which can possibly arise. H:))
hogwarden posted Mon, 27 February 2006 at 6:42 PM
The offer for your free copy of the Figure Independent Injection Plugin will vanish in 24 hours!!! You must install the PBooost II upgrade or full version in order to secure your free copy of this indispensible plugin so act fast before the download expires! Howard:)
hogwarden posted Wed, 01 March 2006 at 4:17 PM
I'm pulling the free download at 12PM UK time tonight... 2 hours time! If you wish to get the FII plugin free with PBooost II you'll need to act fast:) H:))
Philywebrider posted Fri, 03 March 2006 at 3:57 AM
Hogwarden PBoost was posted before it was available, so I waited. When it was available it was priced wrong an I waited until you/Rendo got it straightened out. I didn't want to cheat you, see line 9. I even explained to someone about why PBoost was no longer posted. See line 14. A question was brought up and I asked for a reply, see line 15. It took 7 days to get an answer. I wasn't able to get on line so now I'm losing the free plug-in, after waiting all that time. See line 18. I just can't win.
hogwarden posted Fri, 03 March 2006 at 7:07 AM
Hi Philly... sorry about the delay in answering your post 15... not sure why I missed it:( I'm e-mailing you the plugin:) H:))
Philywebrider posted Fri, 03 March 2006 at 7:15 PM
Hi Hogwarden, many thanks, I sent you my e-mail address but no plug-in yet... :O(
