Frankly3D opened this issue on Feb 23, 2006 ยท 4 posts
Frankly3D posted Thu, 23 February 2006 at 1:26 PM
I want to modify Koji head a little in he has a damaged eye and have the lid shut, with a scar running down as face as per rough example.
Is this done in Poser, UV mapper or what.
Do I need to remove the eye from obj or just keep lid closed.
And how do I extract the changes I made from the original?
WIP
http://www.frankly3d.com/wip/wip_koji.jpg
Miss Nancy posted Thu, 23 February 2006 at 4:28 PM
it's done as a bump/displacement map on a template of the head texture, which one can generate in uvmapper. I would just keep the lid closed. don't understand third question, as the new bump map is separate from your original texture map.
Frankly3D posted Thu, 23 February 2006 at 4:58 PM
(Part 3)
I was hoping along with the scar , a physical depression could be put in the skull.
Miss Nancy posted Thu, 23 February 2006 at 5:36 PM
there is no skull - just the surface polygons you see, which represent the face skin. the displacement map causes the rendering engine to produce a result that will resemble a physical depression.
