Netherworks opened this issue on Feb 26, 2006 ยท 12 posts
Netherworks posted Sun, 26 February 2006 at 3:58 PM
PC only, due to TKinter.
For morphers, this script takes a multi-grouped .obj file which has been morphed into another application and transfers the individual morphs to the figure in the scene. It will only work on morphs made for the target figure.
The original script, which is freely redistributable, was created by svdl and I simply added the TK GUI and selectable options.
http://www.netherworks-studios.com/nws-utility.htm
svdl posted Sun, 26 February 2006 at 4:00 PM
Great addition to the script! Thanks for sharing.
pitklad posted Sun, 26 February 2006 at 4:09 PM
what is the TK GUI?
That script sounds great!
A great time saver!
Thank you sooooo much!
Netherworks posted Sun, 26 February 2006 at 4:13 PM
TK GUI - Tkinter dialog interface. Broken, as I understand it in MAC OSX, so it's marked PC-only. I do believe that Mac users using ProPack and an earlier OS can use it though.
jancory posted Sun, 26 February 2006 at 5:06 PM
thanks! i was hoping you'd figure this one out!
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
SWAMP posted Sun, 26 February 2006 at 9:15 PM
Doesn't work with ProPack.
Netherworks posted Sun, 26 February 2006 at 9:33 PM
Oh, SWAMP, well that's not good :(
Okay, I'll mark it as being P5/P6 only - though I guess it might not work in P5 (on P6 mostly here) Was that ProPack on Mac or PC?
Message edited on: 02/26/2006 21:34
SWAMP posted Sun, 26 February 2006 at 9:42 PM
I'm on a PC. It does work fine in my Poser5 though.
Netherworks posted Sun, 26 February 2006 at 9:53 PM
Well basically I only did the interface and options for svdl's work so it must be using Methods that were only revealed as of Poser 5. ;)
svdl posted Sun, 26 February 2006 at 10:03 PM
That's correct. The SpawnFromGeometry method was introduced with Poser 5. There may be a workaround for ProPack, consisting of enumerating the vertices in the loaded geometry, calculating the differences with the corresponding geometry of the body part, and create the deltas from that difference. Not very clean, and probably pretty slow. I'm rather busy with my day job, I won't have the time to write that script.
RawArt posted Mon, 27 February 2006 at 7:56 AM
Oh...you are kidding me! I was looking for just such a thing this weekend, too cool :) (after I did it all by hand sunday :p) Rawn
odf posted Mon, 27 February 2006 at 7:33 PM Online Now!
Sounds great. Many thanks!
