juhaka opened this issue on Feb 28, 2006 ยท 3 posts
juhaka posted Tue, 28 February 2006 at 4:54 AM
http://www.renderosity.com/viewed.ez?galleryid=1166571&Start=1&Artist=juhaka&ByArtist=Yes I have made this picture for Teena contest here at rosity, now i have an idea that i could add jumping dolphins around her, problem is that i deleted the psd file after i finished this one, is there a way to render dolphins to this one so that dolphins actually fades partly to the water, i am using P5 if there is some node settings to do so. Thank you
Chippsyann posted Tue, 28 February 2006 at 7:11 AM
Sounds like Photoshop post work is needed. Do your render of the dolphins, then use photoshop to merge the two pictures into what you want. "problem is that i deleted the psd file after i finished this one," If you have the space on your system; "always save your work" you never know when or if you'll need them again.
juhaka posted Tue, 28 February 2006 at 8:21 AM
Thank you Chippyann i think i figure it out ! I actually rendered new image with alphachannels on and also used the previous one on plane prop http://www.renderosity.com/viewed.ez?galleryid=1167381&Artist=juhaka&Start=1&ByArtist=Yes Cheers Juha
