TygerCub opened this issue on Mar 27, 2001 ยท 5 posts
TygerCub posted Tue, 27 March 2001 at 8:22 PM
Dmentia posted Tue, 27 March 2001 at 9:18 PM
I havent figured that out either, but what I do, is render the bump as the texture until it looks right, then I load it up as a *.bum and apply the real texture...maybe it'll help...shrug
TygerCub posted Tue, 27 March 2001 at 9:34 PM
Doh! It's late and I'm tired. Wha???? Are you saying you load the .bum "texture" on INSTEAD of the skin texture? I'm sure what you said is simpler than I'm reading... TygerCub (wandering off to bed now)
Dmentia posted Tue, 27 March 2001 at 9:40 PM
yes load the image you are creating the bum with (ie the black and white bumpy version) as a texture, and work with it that way until its right...then allow poser to convert it to a bum or convert it yourself, and load it up correctlly and apply your skin texture...it looks kind of funky, but it does allow you to see that everything lines up properlly without having to restart poser...the other option is saving it under a new name each time you change it (very time consuming)...
TygerCub posted Wed, 28 March 2001 at 5:41 AM
Ah! Okay. I'm awake and more coherent now. thanks for the advice. I did try that a little last night and it does, indeed, look funny, but I understand the point of using it that way. I'll try working with it like that a while and see if it works for me. Thanks again for your invaluable help!
