anxcon opened this issue on Mar 03, 2006 ยท 12 posts
anxcon posted Fri, 03 March 2006 at 1:29 PM
E constant, what is it? i know its a dumb question :P just never seen it in math
ominousplay posted Fri, 03 March 2006 at 2:11 PM
Energy Energy = mass x speed of light... or... Elevation or...
Never Give Up!
anxcon posted Fri, 03 March 2006 at 2:20 PM
me <-- confused :x
ominousplay posted Fri, 03 March 2006 at 4:13 PM
What context are you reading or using the "E constant" in. R
Never Give Up!
anxcon posted Fri, 03 March 2006 at 4:25 PM
in the manual is a list of things you can use in formulas working on shaders now, E and Pi are listed for constants i get Pi (duh) but E?-_-
ominousplay posted Fri, 03 March 2006 at 4:27 PM
Sorry, can't help. I don't have a clue. Energy wouldn't be applied here, would it? Maybe elevation... Good luck
Never Give Up!
ramble1035 posted Fri, 03 March 2006 at 6:04 PM
It's a magic constant. e=2.718281828... It is used in various formulas like natural logarithms (log to the base e rather than log to the base 10), but I'm not sure of much more. It's been a long time since I had to deal with it.
Singular3D posted Sat, 04 March 2006 at 4:17 AM
Attached Link: http://www.ndt-ed.org/EducationResources/Math/Math-e.htm
Sounds like I have to look into my mathematic books again. Studied electronics on the university which includes extensive mathematics. Just remember there was a constant called 'e'. More info on the link... Just have no idea what it can be used for in Carrara...johnkramar posted Sat, 04 March 2006 at 11:41 AM
e is usually defined by the equation:
e = limit of (1 + 1/n)^n for n from zero to infinity
The number e was first studied by the Swiss mathematician Leonhard Euler in the 1720s, although its existence was more or less implied in the work of John Napier, the inventor of logarithms, in 1614. Euler was also the first to use the letter e for it in 1727 (the fact that it is the first letter of his surname is coincidental). As a result, sometimes e is called the Euler Number, the Eulerian Number, or Napier's Constant (but not Euler's Constant).
An effective way to calculate the value of e is not to use the defining equation above, but to use the following infinite sum:
e = 1/0! + 1/1! + 1/2! + 1/3! + 1/4! + ...
ref: http://mathforum.org/dr.math/faq/faq.e.html
anxcon posted Sat, 04 March 2006 at 2:10 PM
o.o' thanks
Singular3D posted Sat, 04 March 2006 at 3:12 PM
Still don't know what it can be used for in Carrara ;-))
anxcon posted Sat, 04 March 2006 at 3:33 PM
creating a 3d calculator =P
