ookami opened this issue on Aug 18, 1999 ยท 3 posts
ookami posted Wed, 18 August 1999 at 9:10 AM
Ok... here's another question for you Bryce/Poser gurus. I imported the figure , applied the texture map, applied materials to the props... but the image looks "washed out". Are there any special settings I need for the poser texture to look "right"? I don't know Bryce very well at all, so I don't even know where to begin. Is there any special settings (Ambience, etc.) that should be a any particular settings? Thanks, as always!
ScottK posted Wed, 18 August 1999 at 11:56 AM
Diffusion should be at 100 Ambience should be close to 0 (0-5, according to preference) Sometimes a touch of specularity is nice. You may also want to adjust the ambient, specular and specular halo colors according to the lighting in your scene. Keep in mind that, unlike poser which multiplies the texture map with the base material color, Bryce uses white for the material. You may need to adjust your texture map accordingly, in Photoshop or another image editor. -ScottK
Spike posted Wed, 18 August 1999 at 12:47 PM
Set to blend transpairentcy Spike
You can't call it work if you love
it... Zen
Tambour
