As you can see in the small picture how the leotard imports on i'ts own, Well you need to uncheck those extra bits Lthigh,Rthigh etc. when exporting from poser. Then in the texture selection screen in bryce. 1. Load the swimsuit texture 2. In the miidle box load the trans map and select the little half white half black circle.(invert selected alpha image). And the other settings are shown in the image. It should work now. By the way this is for bryce 3d I Bryce4 should be the same. Anyway it's nearly 2.30am and I have to get up for work at 6.30 so I'm off to bed. See ya all later Regards Marc..
Thanks, I'll give that a try!
You da man! It worked! Cool! Thanks!
