Forum: Carrara
Subject: Latest bug list.
Kixum opened this issue on Mar 11, 2006 ยท 11 posts
Kixum posted Sat, 11 March 2006 at 5:17 PM
Attached Link: http://backroom.renderosity.com/~carrara/c505bugs/index.html
I sent the link to Eovia. -Kix
-Kix
steama posted Sat, 11 March 2006 at 5:41 PM
Good job Kix! Thank you
Tunesy posted Sat, 11 March 2006 at 6:31 PM
Good job. Don't forget the one (or maybe two) in realistic skys. (See the thread a few below this one.) Combined it makes it quite an ordeal to set up a customized realistic sky.
Message edited on: 03/11/2006 18:32
anxcon posted Sat, 11 March 2006 at 6:47 PM
also a bug in formulas, ie i can type red=sqrt((axax)+(ayay)+(azaz)); and it works, however if i do this=sqrt((axax)+(ayay)+(azaz)); red=this; then red seems to be always be 0, so guess its a bug a couple threads down has a formula from me seems easy values work, like this=1; red=this; works, but still, should calculate the longer ones
anxcon posted Sat, 11 March 2006 at 6:52 PM
another bug in formulas, any formula longer than 6 lines the text box seems to lose its scroll bars, the info remains there and works fine, but can't edit it without clicking on an existing line, and hitting enter key, then ofcourse backspace to get rid of the line the enter key made
ren_mem posted Sun, 12 March 2006 at 12:00 AM
anxcon, I don't work with formulas so am not sure of the proper syntax rules in carrara.There is limited docs also. Is it possible that is the cause of the error w/ long calcs? That the parenthesis used improperly or lack or quotes etc... could be killing the value?
No need to think outside the box....
    Just make it invisible.
ren_mem posted Sun, 12 March 2006 at 12:09 AM
Oh, I see. I missed the first test you did before the red variable.Yeah that does look buggy unless there is some odd syntax rule going on.Is there a syntax ref anywhere for this?
Message edited on: 03/12/2006 00:09
anxcon posted Sun, 12 March 2006 at 10:28 AM
dunno, even if i reduce everything to simplest possible steps i'm still getting it, if i drop all of it,and just make it all 1 long line, giving it to red directly, still doesnt work previews and renders, if only previews i could live with it
Primitive_Dave posted Mon, 13 March 2006 at 12:26 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2583465
They didn't fix the issue with surface replicated objects generating vector motion blurs when there shouldn't be any -- see linked message.
SF to LA: From June 1 to June 7 2007 I will be riding my bicycle 545 miles to help support people living with HIV/AIDS. Please visit my homepage: http://www.aidslifecycle.org/6010
ren_mem posted Mon, 13 March 2006 at 5:42 PM
I know that one was acknowledged.
ShawnDriscoll posted Tue, 14 March 2006 at 12:43 AM
It's still there in 5.05!
