geep opened this issue on Mar 11, 2006 ยท 31 posts
geep posted Sat, 11 March 2006 at 6:09 PM
It's easy ... All you need to do is ...
CLICK HERE for Pages 1-10.
Happy viewing. ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Bobasaur posted Sat, 11 March 2006 at 6:16 PM
First! First! First!!!!!!
operaguy posted Sat, 11 March 2006 at 6:35 PM
Got Popcorn, hit me!
pakled posted Sat, 11 March 2006 at 10:48 PM
hey, iss late Saturday night, hic, and I don' shee nuthin' diffrent..;)
Bobasaur posted Sat, 11 March 2006 at 11:40 PM
Hey pakled, I don't have any freebie models or tutorials or textures to offer, but I can give you this. Kevins Kahlua! 2 pots with 1 quart of water in each 2 ounces of freeze dried coffee 6 cups of sugar 1 pint of Everclear 1 ounce of pure vanilla extract Bring both quarts of water to a boil. Mix the coffee into one, and sugar into the other. After each one is completely dissolved let it cool down. When both mixtures are about room temperature, mix them together and add the Everclear and vanilla. This makes 40 proof (20 percent alcohol) Kahlua that is great on ice cream, in hot chocolate and in coffee (among other things).
mystmaiden posted Sat, 11 March 2006 at 11:52 PM
Woot! Kahlua made with Everclear! (Barks at the moon) sounds good :) Now.. I was going through the aformentioned tut. I'm wondering if I am misunderstanding 'shadow catch'. Using Poser 5 and the instructions from the tut, (providing I didn't goof).I rendered..and the shadow went away. Is that right? Mystmaiden
geep posted Sun, 12 March 2006 at 4:24 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2135884
Hi Mystmaiden,It does work as shown but with a few caveats.
You can use only 1 infinite light.
Adding more lights appears to "wash out" the shadow.
Spotlights do not appear to work properly.
You may use the ** Attached link:** to read the original thread on this subject.
cheers,
dr geep
;=] P.S. See post #3 in the above referenced thread. ;=] Edited to remove all cuss words, dirty jokes, references to NVIATWAS, TOS violations, speling airors, and ALL Top Secret information. (sorry 'bout that) ;=[
Message edited on: 03/12/2006 04:27
cheers,
dr geep ... :o]
edited 10/5/2019
mystmaiden posted Sun, 12 March 2006 at 11:34 AM
Many thanks, Dr Geep! Myst
geep posted Sun, 12 March 2006 at 11:45 AM
My pleasure, I'm always glad to help a lady. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
operaguy posted Sun, 12 March 2006 at 12:11 PM
WOW! A theatrical short before the main picture. Will there be a Silly Symphony cartoon next?
geep posted Sun, 12 March 2006 at 1:20 PM
Um, I think NSG's werkin' on it ... ... so don't hold yer breath. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Hawkfyr posted Sun, 12 March 2006 at 1:32 PM
Casette posted Sun, 12 March 2006 at 5:22 PM
yep
CASETTE
leather-guy posted Sun, 12 March 2006 at 7:26 PM
BkMrrrrq
geep posted Sun, 12 March 2006 at 10:33 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 12 March 2006 at 11:36 PM
cheers,
dr geep ... :o]
edited 10/5/2019
AntoniaTiger posted Mon, 13 March 2006 at 3:42 AM
I've noticed some odd things happening when the Focus Distance Guide is on while re-framing the scene, most obviously affecting the camera Scale parameter. The camera controls operate on camera-aligned axes, and I suspect that Camera-Z is locked and Camera-Scale changed instead. I've also seen the location of the guide within the frame change. Are there things happening similar to the lens movements possible with some cameras, changing the view without the distortion arising from a camera tilt moving film and object plane out of parallel.
geep posted Mon, 13 March 2006 at 4:46 AM
Hi Antonia,
re: " I've noticed some odd things happening ..."
With Poser ??? ........... Nah! ............... Not with good ol' Poser. ;=]
As I have said many times before, with Poser, all things are possible, or should I say poseable.
Your point(s) is (are) well taken. Poser's camera has many variables but one should not expect it to operate in exactly the same fashion as in the "real" real world.
In addition, the focus guide should only be used with the Main (or Aux) camera. The other cameras appear to have some idiot-synchroncies [sic] that don't allow the Guide to work properly, or it doesn't make sense to use it, e.g. the Front camera because there is no zScale.
I will try to address your concerns if I can but they really fall outside the scope of this tut. Let me see what I can do for you.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
AntoniaTiger posted Mon, 13 March 2006 at 5:28 AM
I think that at this stage it's just that some odd things might happen, and some controls ought to be avoided when the guide is in use. I do tend to think of these things in light of my experience with cameras. And sometimes these oddities turn out to be useful.
geep posted Mon, 13 March 2006 at 5:56 AM
Yup ... what you said. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
jonthecelt posted Mon, 13 March 2006 at 7:58 AM
bkmk
geep posted Tue, 14 March 2006 at 5:52 AM
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
jonthecelt posted Tue, 14 March 2006 at 6:50 AM
Any suggestions on how to corroborate the 'fstop' seting to the finished renders results? If the traditional - ie., real world - settings don't have a parallel in Poser, then how do you know, beyond tweak and test, where to set the fstop value? jonthecelt
AntoniaTiger posted Tue, 14 March 2006 at 7:47 AM
Briefly, the Poser camera focal length and fStop settings work on the depth of focus pretty well as they do for a real camera. The important thing to remember is that we cannot see the difference between an in-focus and an out-of-focus blob until it looks big enough to our eye. "Big enough" is a matter of angles, and it depends on the distance of the picture and its size. So your snapshots can look bigger than an advertising hoarding. What I'm getting to is that Geep's sample pictures are very small, and to show the difference in focus he had to use a very small fStop. The default in Poser is fStop=2.8, and that will show blur in a screen-filling web image. For an example, I often use a focal-length setting of 85mm for my pictures of people. For that, the in-focus range is the equivalent of about 10 inches deep at f2.8, and it gets shallower as you get closer. For an idea of the way things work out, look at this PDF for the Leica Noctilux f/1.0 5cm lens, which has some real-world depth-of-field diagrams.
geep posted Tue, 14 March 2006 at 8:56 AM
@ jonthecelt
That is an excellent question. Let me see if I can come up with something that will work in Poser.
cheers,
dr geep
@ AntoniaTiger
Your observations are exactly correct. I needed to use small values to amplify the effect for this tut so the effect would still be visible in the reduced size graphics.
Thanks for your response and input.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
jonthecelt posted Tue, 14 March 2006 at 9:46 AM
Ok, that's fine. I understand now. In fact, there's a useful application I picked up some time ago, called fcalc. It allows you to input the lens focal length setting and desired depth of field you want, and will tell you the f-stop settings required. Of course, it's designed for normal cameras rather than Poser settings: I just wanted to make sure that I wasn't being completely stupid in trying to use it for my more digital creations. jonthecelt
Bobasaur posted Tue, 14 March 2006 at 12:13 PM
Hey, watch it there! There are a lot of us in the "attempting completely stupid things in making digital creations" club.
geep posted Tue, 14 March 2006 at 1:11 PM
You guys got a club ???
I didn't know that.
cheers,
dr geep ... :o]
edited 10/5/2019
Bobasaur posted Tue, 14 March 2006 at 2:12 PM
Oops, I blew it. It was gonna be a surprise announcement at your CD Release Party. I guess that's why they voted me as president.
geep posted Tue, 14 March 2006 at 3:15 PM
President ???
Oh, I thought you said precedent.
Nevermind.
P.S. Oops, you blew it.
There was gonna be a surprize party for the release of the CD.
Now I'm not sure I want to let go of it.
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 02 April 2006 at 10:15 PM
Attached Link: http://myweb.cableone.net/geep/
CD? ... Did somebody say CD?Check it out RIGHT HERE.
cheers,
dr geep
Edited to remove all cuss words, dirty jokes, NVIATW(or WO)AS, TOS violations, speling airors, and all TOP SECRET information. Message edited on: 04/02/2006 22:17
cheers,
dr geep ... :o]
edited 10/5/2019
