dfsmetsfan opened this issue on Mar 12, 2006 ยท 15 posts
dfsmetsfan posted Sun, 12 March 2006 at 8:21 AM
A friend is having a problem with her poser pngs. Apparently they're not showing transparent. We had this issue come up before but I can't remember the solution to have them show transparent again. I'm assuming it's with poser 5 but it could also be 6. In any event, if anyone knows how to fix this, it should work for both programs. TIA. Any assistance would be greatly appreciated. Donna
Miss Nancy posted Sun, 12 March 2006 at 4:33 PM
sounds vague. tell her to post one of 'em.
Mystic-Nights posted Sun, 12 March 2006 at 5:31 PM
When I create a prop in Poser 6, the png thumbnail sometimes does not have good color or quality and it shows the floor grid. I enlarge the prop size to fill a 500x500 viewport and then render to 91x91. Export as a png and save to the props folders. Click yes, when it asks you if you want to replace the thumbnail.
LostinSpaceman posted Sun, 12 March 2006 at 5:41 PM
If it's just the ground prop showing that's got your goat, just unclick the visibility eye setting for the ground in the heirchy editor before saving the figure or prop to the library.
Acadia posted Sun, 12 March 2006 at 5:43 PM
I don't seem to have a problem saving my images as .png files. Poser 5 and 6 saves them with a transparent alpha channel. I offere poser 'tubes' to the graphic community and I have them in .png format. Until a couple weeks ago I hadn't heard of anyone having any problem using them. Someone contacted me saying that when they open any of the .png files into their graphic program that it has a background...when it shouldn't. I suggested that if that was happening, that after opening the image in her graphic program, that she should go to her selections area and "load from alpha channel" and it would clear away the background. It worked for her. I'm not sure why she and your friend are having that problem with .png files, but loading from alpha channel in the graphic program might be the fix she needs.
say." - Ghandi
dfsmetsfan posted Sun, 12 March 2006 at 6:28 PM
Her hard drive crashed. Here's what she wrote: "I have installed Poser and I notice my PNG files aren`t transparent" These are the png files that worked fine with the proper transparency before she reinstalled. HTH Donna
Acadia posted Sun, 12 March 2006 at 6:35 PM
Which PNG files is she referring to?
The ones in her library?
The renders she is saving as .png?
If you can open .png files inside your graphic program, have her do a render, save it as a .png file, zip it and then email it to you so you can open it in your program to see if it's transparent for you.
Post back the results :)
Message edited on: 03/12/2006 18:35
say." - Ghandi
dfsmetsfan posted Sun, 12 March 2006 at 6:42 PM
I believe iit's the one in her library that aren't showing transparent
dfsmetsfan posted Sun, 12 March 2006 at 6:43 PM
Going to ask her to do that. Will post when I get reply
Acadia posted Sun, 12 March 2006 at 7:11 PM
To my knowledge the ones in the library aren't transparent. They will have whatever background you assign to it.... if you save a prop or a light it will give you a .png of the image you are seeing on your screen. If you want a different .png thumbnail, you change the size of your render to 91 x 91 and then render over whatever background colour you want and then save it as the name of the old .png.
say." - Ghandi
EnglishBob posted Mon, 13 March 2006 at 4:20 AM
Yes, library PNGs do use the alpha channel for transparency. If you add something which is by itself in the scene, i.e. with nothing solid behind it, it will appear on the library background. I do recall something about a bug, or maybe an inconsistency with PNG alpha handling, but I can't find a good reference (can't find anything in this $%^&* forum since the search function was improved beyomd repair). However all thumbnails suddenly losing their transparency after reinstallation sounds suspicious, and I wonder if the image handling libraries somehow got corrupted. Another reinstall might be worth trying.
dfsmetsfan posted Mon, 13 March 2006 at 1:50 PM
I just got a file from her so let me see what it looks like and I'll attach the file....will be a bit but I'll get it up there.... Thanks...I will also suggest she reinstall...
R_Hatch posted Mon, 13 March 2006 at 11:53 PM Online Now!
I second Acadia's recommendation. You get a much better idea of what the library item is, plus your libraries will look a whole lot nicer. Also, I have yet to see one fail to properly display transparency this way. Acadia: the ones Poser puts in the libraries have transparent backgrounds by default, but some odd circumstances can cause flakiness to occur.
semidieu posted Tue, 14 March 2006 at 5:54 AM
I think i remember something like the png show the transparencies only when the monitor is set to 32bit colors. Not sure...
dfsmetsfan posted Tue, 14 March 2006 at 2:33 PM
Thanks...I've been busy and haven't even had a chance to look at what she sent yesterday.... I'll ask her about that, though
