drafter69 opened this issue on Mar 12, 2006 · 7 posts
drafter69 posted Sun, 12 March 2006 at 10:35 AM
Can someone point me to the basic information I will need to learn how to create props? I am quite new to this and would very much like to learn. Thank You
wheatpenny posted Sun, 12 March 2006 at 10:55 AM Site Admin
To create a static (non-posable) prop, simply import a model a,d scale it and set the materials, etc, the way you want it, then save it to the props library. To make a "smart-prop", you need to follow the same proceedure, but parent the item, then save it and a dialogue will come up asking if you want to save it as a smart prop. Posable props are a bit more complex. I believe dr geep has some tutorials that can give you more information on making props.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
mdbruffy posted Sun, 12 March 2006 at 11:41 AM
It also depends on weather or not you're working with meshes or with primative shapes. In either case, it should be fairly simple- nine times out of ten anyway. Just get a drawing or picture of the prop you want, figure out the basic shapes that go into it's appearence and then combine the primatives - if you have the right ones- into the shape. Sometimes you might have to export the assembly and re-import it if you're doing alot of adding-on. not to blow my own horn, but you might check out the modeling gallery or my gallery and take a look at the train I'm working on. I'm building it entirely in Poser out of Poser primatives and primative sets I've tracked down. Might give you some idea of a direction to take.
geep posted Sun, 12 March 2006 at 12:05 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2063281
Hi drafter69,... Tuts on making props ???
There are a few. (grins)
Use 'em in good health.
cheers,
dr geep
;=] P.S. Here's an Rx - Read 2 and IM me in the morning. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
drafter69 posted Sun, 12 March 2006 at 12:49 PM
Thank You so very much. Looks like I have some reading to do. Ron
geep posted Sun, 12 March 2006 at 1:19 PM
;=] My pleasure. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mdbruffy posted Mon, 13 March 2006 at 6:17 PM
drafter- just found a set of primative shapes for sale at www.animotions.com. This is the link. It's only $10.00 for 16 basic objects. https://www.animotions.com/modules.php?name=vStore&op=prod&cid=183&pid=11396 hope it helps. mdbruffy
