Forum: Carrara
Subject: My biggest problem with carrara
dirk5027 opened this issue on Mar 13, 2006 ยท 10 posts
dirk5027 posted Mon, 13 March 2006 at 7:25 AM
Is the production frame, last night I was playing with an image and the production frame completely disappeared and yes I clicked view and show production frame, it was nowhere to be found, so needless to say when I hit render it just rendered black, I was on camera 1. now also in the manual it says to resize pull the dots on the corners, so I do that, it resizes rectangle always, how in the world do you do a tall (not wide) pic. I hope this makes sense, early in the morning here in florida
Message edited on: 03/13/2006 07:26
Patrick_210 posted Mon, 13 March 2006 at 7:38 AM
You can go in the render room and uncheck "keep proportions", then you can drag the corners to any proportion you like. Or, also there you can manually type the numerical resolution. You should be careful of too much zooming with the trackball controls in the camera view. A black render tells me you zoomed way, way out or inside of something. If you hve this problem you can create a new camera in the default position and delete the first one.
Hoofdcommissaris posted Mon, 13 March 2006 at 7:39 AM
Hi Dirk, Go to the render room and un-tick the box 'Keep Proportions' in the 'Output' tab. The disappearing of the production frame could have to do with using the command+option+f (or equivalent) without knowing...?
dirk5027 posted Mon, 13 March 2006 at 8:21 AM
thanks everybody, gonna make a world of difference
bluetone posted Mon, 13 March 2006 at 11:28 AM
You can also use the drop-down in the camera view and choose 'Reset camera' to get it back to the default position if you've lost track of where you are.
ren_mem posted Mon, 13 March 2006 at 1:20 PM
Attached Link: http://associatedfx.com
Also, associatedfx.com has some great free plugins. One is to reset the production frame.
No need to think outside the box....
    Just make it invisible.
dirk5027 posted Mon, 13 March 2006 at 2:11 PM
grabbed it, very nice of all of you thanks
ShawnDriscoll posted Tue, 14 March 2006 at 12:19 AM
Hiding the rendering camera sometimes makes the Production Frame unavailable.
mickmca posted Thu, 16 March 2006 at 7:30 AM
I accidentally reduced the PF to a box so small I couldn't find it. Still not sure how, but I'm sure it was a user error. To solve the problem, I switched to another camera and if I remember correctly, I could see the PF as an object in front of the production camera. I zoomed in with the working camera, grabbed the PF dots, and resized it. Am I imagining all this? M
ShawnDriscoll posted Thu, 16 March 2006 at 2:11 PM
No. You can see the production frame from other camera views and tug on it.
